![]() | Home > Off Topic - Other Cars > Spark Plugs - Which are best |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
The best thing to do is clean the air filter, as you is running too rich matey and your burning unnecessary fuel |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2590 ![]() ![]() ![]() |
Cheers Miggit, I will try the NGK, its a Kohler Command Pro 6. With plug cleaned it starts and runs perfectly but then plug soots up so I assume the carb is running rich as you suggest, will try a new plug first then tackle the carb |
Take the air filter off and try that..... don't blatt it down a dusty track..... but running it stationary wont do it any harm..... and could prove if that's the fault before drastic surgery is advised |
The second picture is exactly the one, will try the air filter option today cheers |
Have you ever thought about an engine upgrade..... something like this could be made to fit....
the air filter is under the plastic cover with the nut on the top.... you'll probably find another nut under that holding the filter on..... there might also be a removable foam band over the filter, this can be taken off, have the crap knocked out of it and replaced..... |
Thanks Miggit, have already dismantled it and cleaned filter, just having problems sourcing spark plug, cant get one till Monday, gap on old one is massive |
Kohler recommend a Champion RN14YC plug.... that's a middle of the road plug, and one of the NGK equivalents is the BPR5ES...... that is the standard Honda plug..... and it also happens to be the standard 3.5 V8 Range Rover plug too. A BP5ES will also do the job, surely they have invented Halfrauds in your neck of the glens.... failing that what about a local Golf Club, most of the kit that they use will be Honda powered, they might have a spare plug |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1419 ![]() ![]() ![]() |
Honda 4 stroke engines also used in lawnmowers, log splitters etc so suppliers of these might have plugs too. But limited point in changing plugs if reason for fouling not eliminated. Only Range Rovers since 1988 |
Manual says NGK BPR4ES, so have ordered one for Monday as no one stocks them, also was told the Denso equivelent is a different one from the plug it had in, I know it wont solve issue but another item eliminated |
The temperature range difference between a BPR4ES and a BRP5ES is minimal and is very unlikely to effect the running of the engine..... it's only when you get it horribly wrong that things can take a turn for the worst.... to low heat range and it could melt , or act like the rods that you heated with a blowlamp on the very early petrol engines, and you'll never turn it off |
