Home > Maintenance & Mods (L322) > Service question
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Service question
Hi Gang
Did a search to no avail but I need to book my 2010 FF in for a service and wonder which one it needs.
It had a service last year at my trusty indy and got oil/air/fuel filter change, oil change and screen wash. Does is it possible to suggest from that which service it would have ben or is that a silly question - I hear of inspection 1, 2 amongst others.
Just wondering what I might be in for money wise (i.e. a big one or not)
As the car has just turned 85K I've also asked for a price on gearbox oil change. No untoward symptoms or issues but preventative as per many many threads on here
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #383260 22nd Apr 2016 9:01pm
rar110
I have my oil and air filter is changed every 10,000km. My tdv8 3.6 has 250,000km. The fuel filter is 30,000km intervals from memory. ______________________________
Post #383273 22nd Apr 2016 11:32pm
pld118
Ash,
I found this on the forum. Ours is a 4.4 TDV8 and is about to have what dealers are referring to as a B service which is a 'big one'. Hope this assists Thumbs Up
EmiratesA380 wrote:
http://www.fullfatrr.com/forum/topic23549....e+schedule
Post #383289 23rd Apr 2016 6:04am
comports
Thumbs Up Excellent - thanks - I suspect its a B service I need..
Good to know Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #383292 23rd Apr 2016 7:01am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Good info but I cant get it to enlarge - does that actually say 150k miles for autobox oil change (towards the bottom). Who would leave it that long? Big Cry 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #383303 23rd Apr 2016 8:30am
pld118
It does say 150k ajac
Post #383331 23rd Apr 2016 10:19am
comports
GULP - I just spoke to my indy when I dropped the car off - his estimate at the point is the B service plus a full Gearbox oil/filter change will come in at around £800-900
Is this about right.I trust him to do a good job but that is a lot. He said it;s a full GB oil change so will drain the box, intercooler, sump etc. New sump/filter
Hey Ho... Its only money I guess. Big Cry Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #383752 25th Apr 2016 6:33pm
Make sure he is using the correct oil for the box, any yes it is pricey!
Iirc an Indy would be about £400ish for the service, the gearbox service kit is not cheap with the oils etc about £260incl vat for the genuine stuff and gen filter, tho these are usually filtrans ones anyway, plus a bit of labour on the box service, so you are there or thereabouts £800. There is nothing that can't be fixed with a hammer😜😜
Post #383757 25th Apr 2016 6:51pm
comports
Hi Gang
No update as to cost yet for the service (cos I said I was not in a rush to pick the car up today) but the report has come back with a clean bill of health apart from "Both rear shocks have slight leaks"
I know Gaz you have mentioned on other posts that "most" Full Fats have dampness around the rear shocks and my indy said worth keeping an eye on them cos they cost £650 +VAT each from LR plus fitting..!
Could I ask however, would these be what he is referring to..? (Linky..?
They say direct replacement and have Continous Variable Damping. These are £265 inc VAT...
I will hold off anyway for now but just planning for the future... Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #383983 26th Apr 2016 9:39pm
comports
Can anyone help on this last question..
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #384312 28th Apr 2016 5:27pm
they appear to be vin specific, so without that its tricky to tell
have a look at www.lrparts.ru (its russian microcar but there is an english button) and with your vin you can get the part no and search for that. Thumbs Up its picture driven so you can navigate it easily, you will want; g-cat 2010-, chassis, springs struts and shocks, rear struts and shocks less armoured with cont variable damping, then click on the 5a669 in blue and match up your vin. Thumbs Up[/url]
edit..... just had a quick look on lrdirect as they tell what supersedes what, and the part no are LR023573 for the RH damper and LR023580 for the LH. :thumbs: so the one in your link would be the LH damper for a 2010 with adaptive damping There is nothing that can't be fixed with a hammer😜😜
Post #384315 28th Apr 2016 5:38pm
Ash, i have never seen a 2009> 322 without leaking rear shocks Shocked
Every single one that i see (including mine) have dampness! Don’t waste your money replacing them pal Thumbs Up
Post #384368 28th Apr 2016 9:05pm
comports
Thanks both for the advice
I will wait and see what happens then based on this - I suspect it has been like it for sometime and has not been picked up on any MOT so far - No affect on ride either so will just monitor it.
Incidentally - Picked the car up tonight from my Indy and it drives VERY VERY Smoothly now it has had the GB oil/filter changed. I never had "any symptoms" anyway but did it as preventative but it has made a BIG difference. I almost cannot feel the gear changes now at all.I only see the revs drop and sound change a little.
(but the service did end up costing me £1073...!! (he did full inspection and all oils/filters including GB oil/filter and brake fluid etc - so she is in tip top health at least.) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #384379 28th Apr 2016 9:54pm
ajac8
Sorry for hijacking an old thread but does anyone know how many litres of Auto gearbox oil are needed for a fluid change. (4.4 TDV8 8 speed)? - without filter change.
The WSM does not say as it is filled for life ( Rolling with laughter ).
Cheers 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #425681 30th Jan 2017 9:03pm
