![]() | Home > Technical (L322) > Suspension |
| Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151
go into eas and then "height" and scroll to "rear axle". hit enter and then use the up and down arrow keys to lift or drop rear. Declan
| n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754
Is it not levelling itself off when you hitch up ??
| chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 766
Yes it does level itself!
I'd agree when first attached it sits down, mine goes around a mile and settles itself off. I'm towing 1800kg with around 110kg on the nose if it helps. Is this where I put the car details and a bit about myself ?........ |
Just beware of insurance companies small print sir... Most won’t allow modifications to suspension heights! |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Mine sits ever so slightly nose down on the ff, it's kinda how it should be.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35877
dont forget the front is a cm higher than the rear from factory..not a lot but can give the impression of a 'nose up'.. ... - .- -.
I have to say, that red FF looks bloody good |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
^^^ It does, but then red ones do |
With that in mind, why are people saying it should be nose down when factory is nose up. 2003 FFRR Vogue 4.4 V8 97 Defender 90 300 TDi |
| All times are GMT |
