Home > Maintenance & Mods (L322) > working on suspension
Declan303
Ireland 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
I'm going to change the bushes in the upper suspension arms on front and wondering if there is a preferred/ recommended position to have the height set to before working on same and removing the arms. Does it matter, should I just leave it in normal height? Declan
2003 FFRR Vogue 4.4 V8
97 Defender 90 300 TDi
Post #383778 25th Apr 2016 8:35pm
miggit
I believe that normal is the correct height for jacking it up Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #383810 25th Apr 2016 11:21pm
Doesn't really matter where you have it, it'll sort itself out afterwards... If your doing it on the drive and are just jacking the front up make sure you leave a door (not the boot) open, this will stop it trying to level the back while it's jacked... Thumbs Up
Ummm... not too sure what you mean by upper suspension arms on the front, it's got a strut and two lower arms...
If you plan on changing the bushes in the lower arms then I hope you have a massive press, I broke my mates 20ton press doing mine, if I had to do them again I'd just buy the whole arm with a new bush... Thumbs Up Pete
Post #383820 26th Apr 2016 12:17am
Declan303
When I said upper I mean the higher (rear) of the two bottom arms if that makes sense. Declan
Post #383887 26th Apr 2016 4:10pm
Thumbs Up Thumbs Up Pete
Post #383912 26th Apr 2016 5:08pm
