![]() | Home > Technical (L322) > Oil change problems. |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
Hi Folks.
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
there are 2.
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
Next time you change your oil .
Thanks folks. I think I will be changing my Indi. |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
How can he call himself an indy ???
The sump plugs should be changed on each service. My worry would be the stripped thread? I would get it to a specialist pretty quick. |
No he didn't have to say anything however he also told me what a massive job it is to change the sump due to having to remove the driveshafts etc. I was more worried about the fact they didn't know it had 2 drain plugs to be honest as I try to keep up with things. The last 2 oil changes have been done incorrectly now as far as I'm concerned. Very annoying! |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Not the same engine but my sump plug thread is on it's way out so I have a helicoil kit and new bolt on standby for the next time I change my oil which would save the sump removal if done carefully. |
Yes I think that will be my plan, what size did you get? |
Try to find out which part is missing threads. If it is the plug, they can be replaced but if it is the oil pan, then a helicoil should do the trick. Get someone who knows how to do a helicoil properly though !!!! MY 2010 5.0 SC Galway green and sand interior!!
Yes it's the pan unfortunately. |
This is similar to the one i purchased. My engine is the 4.4 V8 petrol M62 BMW engine 2004 http://www.ebay.co.uk/itm/M12-X-1-5-X-16-3...Sw5ZBWMjzt |
Thanks mate |
That is likely to be a different size to what you need though |
