Home > Maintenance & Mods (L322) > rear shelf cleaning tips please
HGv driver
Wales
whats the best thing stuff to clean my rear shelf? its sand coloured and a bit grubby any recomandations, i was thinking of a power wash but any other tips would be welcome
Post #383885 26th Apr 2016 2:54pm
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
yes i found the only way was to hose it all down/power wash it all
problem is if you wet it anywhere it leaves dirt rings round where you have cleaned so the only real way is to do it all at once and leave it out in the sun to dry.
mine is also sand and now looks great.
Post #383886 26th Apr 2016 3:01pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Buy a new one!!!
Post #383901 26th Apr 2016 3:48pm
Strong solution of washing powder and scrub a nail brush outside on some paving etc.
Then hose off and allow to dry.
This works well on my ivory shelf so sand should be no problem. Thumbs Up
Post #383904 26th Apr 2016 3:51pm
If you drive HGV's you should be able to get some TFR, I sprayed mine with neat TFR left it 5 mins then jetwashed, good as new... make sure you rinse it well off or it will rot.... Thumbs Up Pete
-Click here for Thread-
Post #383910 26th Apr 2016 4:07pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Had a sand one on my old one, used some vanish diluted , scrubbed it on with a brush, came up brilliant.
Post #383916 26th Apr 2016 4:25pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Genuine question rather than a suggestion.......
Do the learned members think using a carpet cleaner (with small spinning brush attachment) would work? I ask because the cleaner has a good suction phase which removes most of the water after the cleaning phase, leaving it dry enough to put straight back in the car during summer months, I suspect.
Post #383917 26th Apr 2016 4:27pm
No I recon it would damage the surface, it only gets slightly damp, it's mostly plastic...
Carpet machines never seem to get all the cleaner out which could rot it...
Jet wash it, comes up good.... Thumbs Up Pete
Post #383924 26th Apr 2016 5:12pm
Giantlandyman
^ Okay thanks.
Post #383929 26th Apr 2016 5:27pm
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Handy Andy.
My interior is Beige and it works well on the plastic areas too!
Cheers Jerry. THIS WRECKAGE
Post #383942 26th Apr 2016 6:04pm
Mr Tee
Hang on, just remembered, I used the scratchy side of a dish washing sponge, no damage at all, left it in the sun to dry, I did take a picture, I'll go have a look...
Post #383945 26th Apr 2016 6:12pm
Got to do mine as well as I pushed an overnight bag onto it, it unfortunately had rubber feet, and left big black marks on my Ivory shelf Big Cry There is nothing that can't be fixed with a hammer😜😜
Post #383947 26th Apr 2016 6:14pm
CS
I used Autoglym interior cleaner, scrubbing with soft nail brush followed by wet cloth followed by dry towel on my old parchment shelf and it worked well enough. Only Range Rovers since 1988
Post #383948 26th Apr 2016 6:20pm
supershuttle
Well I used hot soapy water (washing up liquid), soft scrubbing brush and rinsed well - in fact hosed and left outside in the sun to dry. Must've been last summer Very Happy Geoff
Post #383953 26th Apr 2016 6:32pm
HGv driver
Wales
thanks chaps i'll get the power washer on it tomorrow Very Happy
Post #383958 26th Apr 2016 6:37pm
