![]() | Home > Maintenance & Mods (L322) > Problem removing viscous fan from pulley |
| Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151
Hope your not caught like I was once trying to remove the viscous fan on my Defender. Was at it for about an hour before copping on that it was a left hand thread. |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965
Luckily I'd worked that bit out before breaking out the 3' leverage bar to get it moving |
| Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267
Mine was a little tight to start and also had to turn many times with a spanner until it eventually turned by hand.Try a little spray and wind it back on ,then off again,if you go onto you tube there are a few videos that may tell you if you are doing anything wrong,good luck ! |
I fear I may have stripped the thread on either the nut or the pulley side (or both |
| mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311
It may actually be free now. Try giving it a little tap towards the rad, with some cardboard to protect the rad itself. Mine couldn't be turned by hand at all, even right at the end of the thread. |
Well the good news is I've finally managed to remove the fan, the bad news is, as I suspected, both the nut & threaded shaft on the bracket are totally cross threaded. A new bracket is around £70 which I'll have to swallow I guess but given only the nut on the viscous fan is damaged, I wonder if anyone knows if it can be replaced - no obvious way of it separating from the viscous unit I can see.
| tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343
oooh, that's not good. At least you didn't break the pulley like I did! Do you need the fan on as some members are driving around fanless?
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1421
I did wonder that too, at least until I manage to locate one at a reasonable cost, but no electric fan fitted on this model so the viscous fan is a must have.
Is it a different fan clutch from a 4.4? You don't need the whole fan. You can have my old clutch with a good nut if you like - I wonder if it would be possible to reuse that side of the housing. |
Thanks Mr Spock, although both petrol, they're listed with different part numbers and mine has SC printed on the part sticker too, whether the clutch unit / electrical connector (or indeed the fan for that matter) are actually any different is questionable. I decided to go all in and order a new one (albeit not genuine, which I think is Hellla in any case, the one I've ordered looks to be Behr, a decent enough brand I think) and be done with it. |
| All times are GMT |
