Home > Maintenance & Mods (L322) > How to remove brake shields 2010MY
So, after the local garage messed about and determined my brake shields are rotten they now rattle like a very rattly thing and I need to remove them.
Does anyone know the procedure for removing them on the later cars, I know the earlier cars needed the hub removing first, but I have read somewhere the later cars it's not as difficult. I am wondering if this is something I can do with some spanners or an angle grinder.
Thanks Discovery 4 HSE
Post #384306 28th Apr 2016 4:59pm
just had a look at rave for the 07-09 cars, and the shield seems to bolt to the front side of the hub assy. you should be able to remove them by taking the disc and calipers off. will go and have a look see.
edit....it does bolt to the front of the hub carrier, but the actual hub flange is probably bigger than the hole in the shield. angle grinder seems likely. There is nothing that can't be fixed with a hammer😜😜
Post #384311 28th Apr 2016 5:25pm
I think it changed for the 2010 onwards cars from what people have said in the past, RAVE is not that up to date though sadly. Discovery 4 HSE
Post #384317 28th Apr 2016 5:42pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
I used tin snips. Can you not put big washers on ? Or are they too far gone?
Post #384344 28th Apr 2016 6:59pm
How close to the fixing bolts is it possible to tin snip them off??
Don't know the state of the fixings as I was wearing a 3 piece suit and unwilling to crawl underneath! Discovery 4 HSE
Post #384378 28th Apr 2016 9:50pm
Mr Tee
I was pretty brutal with them tbh, I got really pjssed off with the embarrassment cause the noise was ridiculous . I think I did quite a few cuts & a fair bit of jiggling about. I would certainly go for the big washer route 1st, no farting about, just do them one bolt at a time, to be honest, all you need is something to be bigger than the corroded hole, you could even notch a washer to slip on without taking the bolt out Thumbs Up
Post #384386 28th Apr 2016 10:33pm
tanertimur
England 2005 Range Rover Vogue Td6 Java Black
I had the same issue with my shield and used "quik steel " which is a putty type compound you play with it like playdoug mixing it. As you feel it heat up you then apply it and it turns very hard hence the name. I applied it on the shield by the hold wedging it and it stopped the shield from rattling.
Hope this helps
http://www.quiksteel.co.uk
I think you can buy on flea bay too. Range rover td6 54 reg touch screen
Post #384507 29th Apr 2016 7:33pm
