Home > Technical (L322) > Brake Issue
AAH
United Kingdom 2007 Range Rover Vogue TDV8 Tonga Green
Brake Issue
I have noticed that when starting up my 3 week old TDV8 (2007MY) after it has been sitting for a day or so the brake pedal is solid. After starting the engine and after a few moments the pedal regains its travel. if the pedal is pumped 4 or 5 times in quick succession with the engine running it goes solid again - this also happens when on the move resulting in no braking which is a bit of a worry! The pedal regains travel and the brakes start working again after about 4 or 5 seconds. When the engine has just been turned off and the pedal is pumped it takes 2 to 3 pumps before the pedal goes solid.
All that aside and in "normal" situations the brakes seem effective and smooth, although they can be a bit "bitey" when dabbed and travelling/crawling slowly.
Could this be a failed or failing brake master cylinder/accumulator?
Sometimes for about 5 minutes or so after the engine has just been started, i can hear a quite intermittent humming/groaning noise come from the front nearside of the engine bay - could this be related i.e brake master cylinder/accumulator recharging?
Another brake question: no matter how hard i try and however much i try and feather the brakes, i find it virtually impossible to stop without a tiny little bump as i come to an actual stop. Is this normal or should i be able to stop without feeling a thing - again could this be related to the above?
Any thoughts?
Many thanks...... Angus
Post #37339 21st Nov 2010 12:45am
Sounds like there might be a slight leak at the servo
Post #37341 21st Nov 2010 1:41am
AAH
going in for its 55k service next week and will get it sorted - hopefully under warranty!
Angus TDV8 Vogue 2006 (2007MY) Tonga/Black
Post #38361 23rd Nov 2010 1:58pm
the noise from the near side just after starting might be the fbh running...i know we got it on the td6 but not sure if you have it on yours... ... - .- -.
Post #38367 23rd Nov 2010 2:03pm
Fox
All diesels have it as standard. Thumbs Up
Post #38371 23rd Nov 2010 2:07pm
AAH
sorry for my ignorance - FBH? TDV8 Vogue 2006 (2007MY) Tonga/Black
Post #38441 23rd Nov 2010 4:09pm
InVogue
Fuel burning heater. It provides warm air to the cabin on these cold mornings (comes on automatically) , and makes the kind of noises you describe Thumbs Up
Post #38448 23rd Nov 2010 4:17pm
