| | Car won't start... Diesel problem? |  |
 Hello,
 I have a 2003 RR td6 and it was in the garage for some months. Usually i go to the garage and start the RR, last week it run out of diesel, so i went to fuel station and buy 10l to put in the tank.
 Job done and i try to start the engine, no work... It cranks but no fire... After many tries i check that the tranparent pipe from the diesel filter have bubbles of air. So i think to bleed the air from system, openning an injector, but with the admission over the rail system, only can open the first injector and didn't work. Solution was dismantle the admission colectors and open the last injector, 5 minutes and the RR wake up finally!!! Car fail for some moments but after 1 min, was perfect!
 Drive the Car for 200 meters and park again to finish all the inspection to the engine.
 Next day in the morning when i try to start the RR the same problem... No fire, air in the filter pipe... All again? Maybe it was not bleed totally? Do i have to take off all the admission again to bleed the air? High pressure pump is not sending diesel with enough pression?
 Some help please...
 P.s. - i can hear the pump working under the Car near to the rear left wheel
