![]() | Home > Technical (L322) > EGR warning - post mortem findings |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
Think that you need to read the reg's again buddy, if you put a new engine in an old car then it has to meet the emission standards for the age of the car....... however if you put an old engine in a new car then it has to meet the emission standards of the year that the engine was manufactured........ that's a win win, if you can be bothered to go through all the hassle of the engine change and integration ![]() ![]() ![]() ![]() ![]() ![]() ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Forgot they could also be doing load sensing on the motor. Ed |
Got a feeling that they is either open or closed and there is nothing in between except when they are all crudded up |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
No, far from "Really" I was speculating, that's why I used words like "wonder" and "probably" I've read hundreds of threads on many different car forums about how much better diesel engines run and behave when the EGR is blanked off or tuned out so one would presume that the TDV8 would be similar.... I was trying to encourage a discussion about an issue which is very much talked about on this forum, at no point did I state any facts or pretend I am an Internet "expert" I don't, however, believe everything I read and I certainly don't believe everything I'm told.......... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
Your the BEST PETE ![]() ![]() ![]() ![]() Like you bud, I fail to see how an engine that requires a good supply of clean air will run well when it's forced to breath some of the exhaust..... it just doesn't make any seance ![]() Having been doing a fair bit of searching about VGT turbo faults.... the biggest cause of failure is soot clogging up the works..... just about the same as the EGR's..... from what I can see you need to replace the missing sulphur in the fuel with either an additive or 2 stroke oil.... this would appear to be the best long term remedy. If you can keep the engine looking like it's just left the factory inside , then everything should work..... When the vanes get clogged up and stop moving in the turbo, it causes over boost... which leads to things going pop and ![]() ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
I don't think you will have much trouble, your engine will get a good work out towing the crappers around...
Based solely on the IID Tool readout the EGRs on the TDV8 are not just open or closed as it reports a percentage and I've seen it reporting that on test drives when I was evaluating the EGRs.
You'll quickly realise that most car manufacturers can't or don't write software particularly well.
