Home > Technical (L322) > 2007 SC just died 150m from home
Page 1 of 3 123>
Dieterf
South Africa 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Morning
I washed the car yesterday, all shiny and clean. Got in 2 hours later to collect at the airport and literally 150m from my house, the rev counter just dropped to zero, coasted to a stop.
Only message is AVoff on instrument cluster, came up as she died.
Cranked to no avail.
Left the car there for a couple of hours and used spare car for airprot trip, came back and still no luck. Towed it home.
The subsequent cranking attempts have killed the battery, tried a booster, still no go.
I'm sure i heard the fuel pump!
Can a weak battery stop the car from running?
Not sure where to start looking this morning.
PS: i have done searches, then some articles that look promising refer to WIKI, where/what is that?
Post #384983 3rd May 2016 6:01am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
How much fuel indicated in tank? Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #384986 3rd May 2016 6:58am
Dieterf
full, actually full and shows full
Post #384987 3rd May 2016 7:02am
battery, alternator, broken belt? ... - .- -.
Post #384989 3rd May 2016 7:37am
ebajema
Maybe the alternator packed up and it hasn't been charging the battery properly ?? Or fuel line/filter clogged or fuel pump fooocked. Have you got a IID or Faultmate for reading the codes ? MY 2010 5.0 SC Galway green and sand interior!!
Post #384990 3rd May 2016 7:38am
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
If the car was running and it came to a halt, and you cranked and cranked until the battery went flat and it still wouldn't start, that points to pretty much anything except a battery/charging issue to me. More likely fuel.
MC
Post #384998 3rd May 2016 8:38am
Dieterf
YUP, i concur.
Just put a new battery in, as the original was 3 years old and we have had a cold snap.
But no difference, must be fuel related.
Have to go on my work trip, luckily have spare car, will come bck to this in a day or three.
Damn.......
tx for help so far
Post #384999 3rd May 2016 8:45am
JamesD
United Kingdom 2016 Range Rover Vogue TDV6 Corris Grey
Sounds like fuel pump to me, get someone to listen near the tank when you turn to ignition II to hear it prime. If you want to check fuel pressure, take the pipe of the rail and run the same test, check it's getting to the motor.
Have you recently run the tank very close to dry?
Post #385002 3rd May 2016 8:59am
Fuel pump, crank sensor, cam sensor, would be my first three things to look at...
Do you have an IID tool or similar, maybe get some helpful info from the live readings section.... Pete
Post #385048 3rd May 2016 12:04pm
Dieterf
Due to work commitments I pushed the car into the garage until I am back on the weekend.
I unfortunately do not (yet) have a IID tool, but has been on the list.
I will check fuel first, only odd thing is that during the excessive cranking I could smell fuel last night.
My radio also went bonkers and the AV warning was on the dash.
I checked for water ingress into the entertainment cubby in the boot but dry.
When I swapped the battery this morning it and the surrounding area was very wet.
Can someone clear up where I can find the live feed page and Wiki as referred to in posts.
I am battling with search and end up with reams of posts totally unrelated bar 1xword that I have chosen as reference.
Post #385084 3rd May 2016 3:54pm
you can find the wiki link in the top right hand corner of the page under the fullfatrr.com and advertisers banners (in red) or otherwise the links in stans signature will take you there. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #385093 3rd May 2016 4:55pm
Dieterf
Thank you Thumbs Up
Many readings to do Shocked
Post #385094 3rd May 2016 5:05pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Washed car, wet battery area, mysterious electrical fault. Too much of a coincidence for me. I would check out that area first, make sure everything is dry and all connections are good.
Post #385097 3rd May 2016 5:10pm
johnboyairey
Maybe you could try disconnecting the battery for 15 mins, and reconnecting.
Possibly, the AV system, is the cause, and is shutting something down.. You could also, tip a gallon in the tank. In case you are wrong.
Post #385105 3rd May 2016 5:45pm
Dieterf
YUP, I agree, wash-wet battery-problem!
I have disconnected the battery, no change, I am convinced theres fuel, filled up a couple of days ago and have done <200km's.
Saturday when i am back, the search continues, THANKS for the moral and guidance support!
Post #385150 4th May 2016 5:30am
Page 1 of 3 123>
