![]() | Home > Technical (L322) > FIXED!! After inlet manifold job, car now won't run |
I assume you have checked for air leaks as well ?? Too much air because a hose is off, could let the ECU think something major is wrong maybe ?
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Update, -got the alcomms software going...cleared all faults, still same. Disconnected battery, left to die, and reconnected. Checked faults....still same. Starts.. Fires up, and immediately dies, as it reaches about 1220 rpm, and if left, MIL light appears. Seems electrical.
I remember that the MAF is not that expensive, maybe fork out for a new one to eliminate the MAF being the issue. It is not very likely that the MAF just failed while you were doing this work but the fact that it makes a difference in or out makes me suspicious............ Maybe give the current one a good clean as well.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1401 ![]() ![]() |
what codes are showing ?
Update, I reset all historic codes, and now I'm getting no codes. ...one other observation, if I try and Rev up the engine as I start it, it will Rev up and die within one second, it has sufficient intake roar, to tell me that I must have an intake huge leak, so guessing the inlet manifold gaskets, may have moved or dislodged as I was fitting it, so will remove intake manifold today, and recheck everything.
I took the inlet manifold off, and checked the gaskets.....all seems ok, so I replaced all parts, and tried it, and this time it went first time, and is running fine.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8755 ![]() ![]() ![]() |
That's a weird one John.... throttle body plug maybe...???
