Home > Technical (L322) > A Bar Spotlights
CharlieBaja
United Kingdom 2007 Range Rover Autobiography TDV8 Buckingham Blue
A Bar Spotlights
So guys i was wondering if someone could help here. I am looking at fitting a pair of old Lazer lights to the front of my FFRR and wondered if i could ride the spot lights off the main beam of the headlight? I suppose i think if it worked off the main headlight on the Defender it should on the RR, will this work?
Also has anyone fitted a full size 48" roof led light bar to their RR yet and if so how and where did you get the light bar from?
Many thanks
Post #385449 5th May 2016 9:40pm
Lights have a dedicated fitting wiring kit sir. That way you can turn them off when either not necessary on the road or weather dictates Thumbs Up
Post #385463 5th May 2016 10:33pm
CharlieBaja
I have the wiring just want to know if i can piggy back them off the main headlight beam
Post #385466 5th May 2016 10:47pm
If you are going to do it, I suggest fitting a relay into the main beam wiring to detect current and activate it to switch on the spots. Whether this will impact on the operation of the main beams and ECUs I do not know....
As Craig says, better to use separate wiring/circuit/switch .
Post #385469 5th May 2016 11:28pm
As i said above... LR make a L322 spotlight wiring kit specifically to fit LR spotlights (or any for that matter) which includes a switch and all the connections... If it were me, i would purchase and fit that sir...
Post #385473 5th May 2016 11:43pm
Don't think you would want the lightbar on the roof on much of the time anyway, lights up there cause so much glare off the bonnet that they don't help much whilst moving and most of the time make it worse.... Pete
Post #385488 6th May 2016 1:04am
CharlieBaja
I only really want the roof light bar as it looks good on the Bond SVR
Post #385594 6th May 2016 6:32pm
Oh, right, I get it...
Put a light bar on this....
And it will look like this....
All makes sense now, did you know if you do hand brake turns in front of women their clothes fall off....??? Whistle Whistle Pete
Post #385599 6th May 2016 7:04pm
Timbo
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Bottom one is a tarts handbag - yours looks far better Pete...
Post #385630 6th May 2016 9:16pm
CharlieBaja
I am guessing with that comment you don't like the SVR look alike and especially with the light bar?
Post #385641 6th May 2016 10:33pm
Timbo
Oh b**ger Charlie - not yours is it? In which case no offence intended 😳
Just that for me the fattie should be a bit more classy than them there sport things!
Post #385645 6th May 2016 10:53pm
CharlieBaja
No mine is the one on three wheels, i just like the light bar ontop!!
Post #385646 6th May 2016 10:55pm
Timbo
Lol fair enough! Could always do a matt black wrap on the bonnet to reduce the glare I guess....
Post #385648 6th May 2016 11:08pm
CharlieBaja
that's what i was thinking
Post #385649 6th May 2016 11:10pm
ebajema
Have a look at EDF post on the EDF shopping cart. He put a really top notch light bar on for the Swedish winters, he may be able to give you some pointers on do's and don'ts Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #385694 7th May 2016 9:10am
