Home > In Car Electronics (L322) > tdv8 rear tv
STU TDV8
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
tdv8 rear tv
Can't get past this on the rear tv am I doing something wrong ??.
Post #385925 8th May 2016 4:42pm
It's an after-market addition & not a Range Rover screen.
Is there a button on the remote with 'menu' or 'return' or 'source' on it ?
Post #385926 8th May 2016 4:46pm
you certainly need to find an exit or back button of sorts.. ... - .- -.
Post #385927 8th May 2016 4:48pm
STU TDV8
Only just bought the car there is no remote Sad
Post #385930 8th May 2016 5:09pm
STU TDV8
Is this not a range rover plug ?.
Post #385931 8th May 2016 5:16pm
I've no idea what that plug is.
The system is definitely not a factory one.
Is there a DVD player somewhere ?
The factory one is installed in the left side of the boot.
Is there a compartment in the rear arm rest ? That's where the factory one would be.
Post #385940 8th May 2016 6:21pm
STU TDV8
The only part in the boot in that area I think is the sat navigation dvd ? , Do you mean the centre seat on the back seat's where something is located? .
Post #385946 8th May 2016 6:35pm
mjdronfield
Yes, the centre seat.....
Yours will be different to my 2011, but you get the idea.
Yours isn't factory, so who knows..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #385952 8th May 2016 6:53pm
STU TDV8
No I don't have anything like that there ?.
Post #385958 8th May 2016 7:42pm
mjdronfield
Had a quick Google search, you could always give someone like these a ring....
http://www.mrx-24-7.co.uk/p0/necvox/373576.htm 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #385960 8th May 2016 7:46pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
As Alistair says, the Necvox systems are aftermarket. I have Sony screens and a Necvox DVD system in the boot in the left hand side panel. I have 3 remotes, one for each screen and one for the DVD system. The DVD system has a magic eye in the cabin for receiving the DVD. If you have a Necvox screen and DVD system, you may only have one remote which does everything (screen and DVD) or separate like mine. When I first bought mine, I found the remotes in a bag in the right hand lower boot storage area, where the towbar box is when fitted. I store them in the top of the front centre arm rest. Hopefully you'll find them somewhere in the car as there are loads of places they could be. Also would expect there to be some headphones too.
Appreciate your system will be slightly different, but photos attached of mine.
Bootspace - DVD changer unit is the big silver box mounted below the GPS drive
Magic Eye in the cabin for DVD system (larger one). The smaller one is for the digital TV unit.
DVD Multi-changer remote (the bottom one partially visible is one of the Sony screen remotes) Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #386066 9th May 2016 1:16pm
STU TDV8
Yeah doesn't look like I have that in my boot . Guess it's probably easier to start again because I guess they just work as a tv screen? ?..I also can't find a remote
Post #386140 9th May 2016 10:00pm
nicksaab
If you select TV on the main screen, does whats on the main screen also appear on the rear screens (even if you don't have an active digital unit it should still show a channel number or AV code on the screen) It is possible that stilll won't show anything if the rear screen mode is looking at the wrong source input. If its like any other Necvox screen you should be able to do most things on the screen without the remote.
The buttons on the screen are
Menu - the one which looks like a door with an open window. Activates the menu and acts as a select
Mode - the one which looks like a circle - should select the AV input - 2 channels, one would be TV the other would be the DVD player input if it was fitted
Up and Down arrows - will select the option, then once menu is pressed will then change the option.
Play around with the input settings and the PAL/NTSC settings on the rear screens with your front screen on TV mode and hopefully you'll pick something up. Current Fleet:-
Post #386147 9th May 2016 10:54pm
STU TDV8
I won't allow me to do anything apart from change the colour or shade etc it's stuck on one screen and that's it .
Post #386159 10th May 2016 5:38am
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
What about contacting the previous owner - ask them if thy have the remote in a draw somewhere?
Simon
Post #386174 10th May 2016 9:16am
