Home > Technical (L322) > Manually changing transfer box range
mr_spock
Hi. I need to set my transfer box into high (or low) as it's between gears at the moment - not neutral either - and my RR is confused. I know I need to rotate the lead screw anti-clockwise to get to high, but what's the safest way to do it? I don't think I can do it with my bear hands, and any kind of grips will mash the splines.
Ideas?
It's a 2003 4.4 petrol.
Post #385934 8th May 2016 6:00pm
You have a few of options:
Wrap the splines with tape to protect them and as you suggest turn with some grips, keeping pressure on as it will spin "out"
Remove the motor cover and refit the motor to the transfer box and spin the armature to move the selector back to high (magents might fall out and be a right sod to get back in, but may reveal your issue....)
Check out the powerful UK TB motor you tube video and make up some connectors to run the motor from a battery, having disconnected the cable.
Find a suitable female splined but to turn the spindle .
Post #385942 8th May 2016 6:31pm
mr_spock
Hmm, I'd considered powering the motor. I've already made up a lead and tested on the bench, so could reuse that. Do you think I could just use the motor, unbolted, to rotate the splines?
I'll ask my wife if she has a splined butt Smile
Post #385948 8th May 2016 6:39pm
I would bolt the motor back on, ensures it winds to the right place, if this doesn't work, then will help with fault finding.
I have same problem, but even the fitting of a new motor won't solve it, so no low range work / off roading for me! .
Post #385972 8th May 2016 9:49pm
holidaychicken
Have you tried switching the box into neutral using the fuse removal process to see if it finds itself, it knows where it is due to the potentiometer I believe and it's this that fails requiring the motor to be replaced.
I removed and stripped my 04 TB last year and the actuator has a quick spiral thread that's is turned by the motor and pulls or pushes the selection fork to move the ring gear, it's only quite a small amount of travel and if you move the ring away too far manually the actuator won't be able to engage and it will be TB out time to strip it.
Post #385976 8th May 2016 10:43pm
mr_spock
When I reattached the motor it went into high and low ok. Then it got confused and threw the trans fail safe. Now it's not quite in neutral - no drive but a little graunchy - so I think the worm gear is still in the middle of its travel.
I tried the fuse 37 procedure but it didn't find itself, possibly because the fail safe code is still there.
I think I'll wait for my code tool, clear the code and try the fuse/recalibrate procedure again. Does that sound like a sensible conclusion to you guys?
Post #385979 8th May 2016 11:18pm
Worth a try Ian, can't understand why it was OK and then not.... Rolling Eyes Pete
-Click here for Thread-
Post #385985 9th May 2016 12:17am
holidaychicken
This is what is inside, not sure if it helps much, RRPhil had a sectioned view on youtube of the actuator moving but it's not there anymore.
Post #385993 9th May 2016 7:23am
mr_spock
Thanks all. I found the youtube vid by RRPhil with the cutaway box, very helpful. I guess it's possible that when I glued the pot together again some glue may have got on the tracks and is somehow blocking movement. My plan is (unless someone has a better idea!):
1. Pull the motor again
2. Test the pot resistance around its whole range again, open and fix if needed
3. Figure out which way the +ve and -ve need to be to drive it clockwise into high range, since that will reduce the risk of the forks falling off the end of the worm gear
4. Reinstall the motor
5. Drive the box into high range with the motor and a 12v supply
6. Clear codes
7. Try again, follow calibration procedure if it doesn't want to play
8. Open beer and cry if required.
Ian
Post #386010 9th May 2016 8:38am
i'd try #8 first... Mr. Green ... - .- -.
Post #386011 9th May 2016 8:49am
holidaychicken
I would try and read / clear any codes first and then try the transfer box neutral procedure.
If it faults out, check what codes you are getting.
When you mention gluing the pot, what have you had apart / glued ?
Post #386100 9th May 2016 4:40pm
mr_spock
I opened the transfer box motor potentiometer to tweak the contacts. I'll be checking the resistance again tomorrow just in case I mucked it up, but I don't think I did.
Post #386134 9th May 2016 8:22pm
mr_spock
OK, it seems to be working now. Although I'll be more confident after some road time, especially when cold. So far:
  • Opened the potentiometer - it only needed about an inch of the lip cutting away, then prised open. It wasn't sealed all the way round by any means.
  • Cleaned the dust out, bent the pins to the side to lie between the wear points
  • Found that the max resistance wasn't as high as it should be - I think that's why it didn't work when I reinstalled the first time
  • Bent the pins down a little to get them even and increase the contact area, then the resistance was much nearer to RRPhil's photo's of his voltage readings
  • Rigged up an 11V PSU from a Netgear switch which I had handy to some mains cable to the motor, run from a switched socket and rotated the motor to match the transfer box position
  • Installed the motor with the cover off, still with the PSU attached, and used the motor to rotate the box fully into gear (high, I think)
  • Tried it out, cleared codes, was in high but wouldn't change, transfer box neutral error
  • Off and on, no errors...
  • Took it off, cover back on, reinstalled but found the box had moved??? No idea how.
  • Realigned the motor, back on, cleared codes and it all seemed to work. Drove a little, changed range, changed back - I can hear the motor so I hope it's good now.
A couple of errors still in the ECU:
Transfer box controller signal fault. Last occurrence - plausibility
Transfer box indicated range
Noise on actuator signal
Motor A and B open load
All seem to be potentiometer related, so I'll clear them and see if they come back now.
I found that you don't need to undo the small torx head screws to get the pot out. I knackered one before realising it doesn't actually hold the pot in, it's just the circular clip that does.
Post #386719 12th May 2016 6:10pm
holidaychicken
I stopped getting notifications, how are you getting on ?
Post #386975 14th May 2016 12:10am
mr_spock
I took it out for a short drive yesterday and had no errors! I think (hope) that's done it.
Post #386998 14th May 2016 8:31am
