|  | Home > Technical (L322) > 2007 SC just died 150m from home |
| Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436    | Ive always thought the AVoff on instrument cluster means that the radio is turned off?
|  4th May 2016 9:55am |
| zarnd Member Since: 22 May 2014 Location: Kent Posts: 459      | You're quite correct it does.
|  4th May 2016 12:09pm |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782      | The SC only has a single pump in the tank, nothing in the engine bay if I remember correctly.  So maybe the relay you think is fuel, isn't.
|  8th May 2016 2:01pm |
| Dieterf Member Since: 24 Apr 2016 Location: Cape Town Posts: 40      | Pretty much did as you said:
|  9th May 2016 5:47am |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782      | I'm looking through my version of the workshop manual and can't find anything that could make the noise you are talking about linked to Relay 5 that is part of the fuel system.  Unless there is some weird echoing going on, there doesn't seem to be anything there.
|  9th May 2016 6:34am |
| kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335      |
 Sound like the electric water pump which is located there. I have a used fuel pump from my SC in the garage, I could check which of the terminals go to the pump if that would help? | ||
|  9th May 2016 7:32am |
| Dieterf Member Since: 24 Apr 2016 Location: Cape Town Posts: 40      | PLease do, if i can figure which wires are pump power i can supply external voltage and see if she runs! | ||
|  9th May 2016 7:35am |
| Dieterf Member Since: 24 Apr 2016 Location: Cape Town Posts: 40      | what i dont get is that Relay 5 (i keep repeating) is marked fuel, if i close it i hear that water pump, but not the fuel pump, but distance wise, also not easy to hear. need anothe rpair of hands/ears/eyes   | ||
|  9th May 2016 7:37am |
| Dieterf Member Since: 24 Apr 2016 Location: Cape Town Posts: 40      | Last thing i tried, with relay exposed and fuel tank sender pipe disconnected, gave the car a swing, did not see the relay close, nor any fuel spew out the sender unit.
|  9th May 2016 9:50am |
| kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335      | May be too late for you, but I've checked and it's the middle two of the 6 pins which feed the pump. The two on either side of the terminal go to the two level sensors. | ||
|  9th May 2016 9:31pm |
| Dieterf Member Since: 24 Apr 2016 Location: Cape Town Posts: 40      | All closed up and ready for the trip to the shop.
|  10th May 2016 3:21am |
| Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 509      | Only just read this post, I know this is a bit late but might help in the future. A mechanic friend showed me this trick if you want to hear something buried in the car. Find a clean bit of hose, stick one end in your ear and place
|  10th May 2016 12:42pm |
| Dieterf Member Since: 24 Apr 2016 Location: Cape Town Posts: 40      | Just had a mail from the dealer, apparently the fuel tank was full of gunk, which blocked the infeed (suction) line and the pump.
|  10th May 2016 3:32pm |
| Dieterf Member Since: 24 Apr 2016 Location: Cape Town Posts: 40      | Collected car last night, 100km's driven since-all ok.
|  12th May 2016 6:37am |
| Posting Rules
