![]() | Home > Technical (L322) > Reverse signal for audio system |
Take a feed directly from the reverse light wiring going into the lower tailgate in the spare wheel well |
| Beemergriff Member Since: 06 May 2016 Location: Northamptonshire Posts: 62
Thanks.
| Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191
let us know where you find the reverse light cable if you do please, a couple of pics would be great
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
Maybe I'm being dumb here, but you have to feed the signal cable from the camera anyway, so not exactly a hardship.....
Depends If op has wireless rear cam or not |
Fair point - I had made that assumption |
I already have the wireless camera mounted and sending to LCD display, but now want it to show on the aftermarket head unit I am fitting to replace the 2-line display (that has the usual defective pixels anyway).
Did you look at taking it over the doors rather than under ?
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
both rear and front sill plates come off and theres sort of trunking where you can lay wires.. ... - .- -.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Be careful going over the top that you don't obstruct the curtain air bags
| berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265
I am not sure on the RR, but it is normal to have a reverse feed to the rearview mirror to inhibit the autodip function when reversing (ie clearer picture)
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
The reverse lights are fed from the LCM which is located behind the side panel in the drivers footwell.
| All times are GMT |
