![]() | Home > Maintenance & Mods (L322) > Transmission Overheating warning message, best way to fix? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8735 ![]() ![]() ![]() |
Trans overheat is a state the box goes into if it overheats, it changes the gear change points to increase the revs of the engine and circulate the coolant faster, it will reset on switch off...
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 ![]() ![]() |
Hi thanks for your reply. The lpg system does require a service. I think my best option is for a specialist to take a look at the vehicle and diagnose the problem. Can anybody recommend anyone in the matlock derbyshire area?
These cars are very easy to work on, if you have done your own repairs before don't be put off by them, the only extra tool you need is a decent diagnostic tool, the IID tool is good and you could easily diagnose the problem yourself (even if you didn't want to fix it) they are not cheap but you will always get most of your money back as they sell well... |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
If the previous owner fitted a new radiator then it is almost certainly the oil cooler[heat exchanger]If you feel the oil pipes to the cooler you should feel a noticeable difference in temperature.Fit new cooler and check the radiator flow with a hose,it should flow freely at full bore and check the date on the radiator if he has supposedly changed it.Change the transmission oil at least twice and the filter in the sump,clean sump.If possible get a live data temperature readout and check against sump temperature[will not be the same but will give you a guide]Iforget the actual temp figures but I think the sensor trips at 140 deg,it should not get anywhere near that but after I had done all the above to mine [and my cooler was almost blocked] the sensor was jumping all over giving high spikes instead of a constant readout,the transmission sensor was faulty and has been ok since I changed that also . |
Hi thanks for the replies. Does the oil cooler/heat exchanger have coolant in it then rather than oil? |
The oil cooler is a water to oil cooler, it uses water from the bottom of the rad to cool the oil, it also works as an oil warmer to warm up the box in cold weather, it is attached to a plastic manifold that contains it's own thermostat.
Had the diagnostic check today. Reading came back as gearbox oil sensor fault. Technician said it is inside the gearbox so I would need a gearbox specialist as it's inside the box. Does that sound right? |
It's part of the wiring loom, so you will have to have the whole gearbox loom replaced, this is not a big job though, drain oil, sump off, unplug old loom, plug in new, sump on and refill....
Thanks for the feedback. This was a land rover specialist in chesterfield that told me that. I will talk to where I usually take my cars and see if they will sort it. It does sound like a simple task n it can't harm to change the oil, do they have a filter aswell? |
Can anybody recommend where is best for parts? And is genuine original land rover parts best to use? I am going to have the filter replaced too plus o-ring and gasket.
Wouldn't go genuine LR as you will pay for the box
Yes this is the wiring harness I changed on mine,also got it from jpat,£100 delivered,there is a video on youtube on how to do it ,just a bit easier after seeing someone else have a go.The temperature sensor is buried in the centre of the loom,you can find it if you poke around.Typical as the torx for the speed sensor at the front was almost slack yet the rear one that is quite awkward to get to was as tight as f$%k,almost thought it was not going to come out ! |
Hi. Thanks for your post. I now have the wiring loom and new filter from jpat, took ages to arrive as zf are moving factories.
It really is easy to do but a lot of garages are scared of the inside of an auto box... Put another post on asking if anyone can recommend a garage or gearbox specialist near you that can do it... Pete
