Home > Technical (L322) > td6 l322 rear wheel speed sensor open cct
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
Latest hdc eas fault, gap says rh rear speed o/cct.
Have tried batt disconnect unplugged abs and cleaned connector any other suggestions before i get the drill out!
Post #368412 22nd Jan 2016 2:30pm
check the abs wire for breaks or chaffing.. ... - .- -.
Post #368420 22nd Jan 2016 3:33pm
bleeperman
Any idea where the plug skt is from the sensor it is not obvious? Been underneath today but access is not good when suspension inactive. If it ever stops raining I will have the wheel off!
Post #368708 24th Jan 2016 6:17pm
dingg1
you need the wheel off , its tucked behind the plastic liner at about the 11 o clock position
Post #368788 25th Jan 2016 9:41am
frenshy
Still showing fault !
Wondered if anyone has had the same problem as me with this..
HDC Inactive and ABS lights on, when diagnosed by a friend with universal diagnostics tool showed "left rear wheel speed sensor" fault. Ive changed the sensor but light still on. Went back to my mate and he says its still showing he same fault and he cant clear it?
Anyone else experienced this?
Post #386494 11th May 2016 6:46pm
It is NOT a hard fault, i.e. it doesn't need turning off it just goes when the fault is fixed.
Pattern sensors are cr@p, always use a genuine one, make sure it is fully home and will go in and out of the hub with no resistance, if you need any pressure to push it home then grind the hole out more... ensure the reluctor ring within the hub is not full of bits of the old sensor and make sure you use the grease that comes with the genuine part... clean the electrical plug as well...... Thumbs Up Thumbs Up Pete
-Click here for Thread-
Post #386504 11th May 2016 7:05pm
dingg1
Make sure you have fiited the correct sensor for yor car , I bought one from ebay as my model was listed as correct , unfortunately this wasn't so , ended up sending the car to well known independent in ncl for diagnostics and they billed me for a repair to loom ( bullshit ) and told me the abs module needed replacement (more bull) they didn't diagnose the wrong sensor was fitted , it was only when I double checked the resistance against against the other sensors that the error was duscovered
Post #386524 11th May 2016 7:35pm
bleeperman
Yes abs sensors are a pain my rear was correctly diagnosed and fault cleared as soon as motion applied. Good tip the old sensor was jammed solid only tool effective was a flat wood drill but grind the point off first and be careful not to damage castle teeth on axle. I had a front sensor diagnosed wrongly once so just change the other to rule sensors out.
Post #386558 11th May 2016 10:49pm
frenshy
thanks
Thanks for the info guys. Took it to a local indy and they saying that its showing an "open circuit" to the sensor and suggesting that its either wiring or more likely, the abs control unit !!
Ive spent a lot of time researching via this and other forums. Its a minefield lol ! Ive seen suggestions that "can bus" errors can cause these probs?? I have changed some of the bulbs for led's - might try changing them back just in case.
Also thanks HAYLANDS for your input - the sensor I have fitted was VERY tight going in, maybe I should remove again and clean the casing some more?
Post #387492 17th May 2016 1:20pm
