Home > Technical (L322) > Wire location and identification
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
I spotted this wire which appears to trapped so ask is this correct ?
Rear on drivers side behind suspension air unit, looks possibly like brake wear cable as goes to hub ?
There is another identical section behind this piece not shown so thinking trapped but darnt pull it.
 Many thanks
Paul
Post #386224 10th May 2016 4:33pm
Pvw10
Any thoughts peeps ? Many thanks
Paul
Post #386472 11th May 2016 6:21pm
It could be, ABS sensor, brake pad wear, height sensor and, depending on model, active damping.... if you have any faults with these then that's the place to start, if not, leave it well alone... Thumbs Up Thumbs Up Pete
Post #386478 11th May 2016 6:28pm
Pvw10
Cheers Pete
Has lights appear the same as last abs sensor fail so was looking for faults and found this, seems ok and fault now gone so will monitor. Many thanks
Paul
Post #386483 11th May 2016 6:33pm
Post #386515 11th May 2016 7:20pm
