Home > Maintenance & Mods (L322) > Tdv8 coolant reservoir level
Page 3 of 4 <1234>
rar110
In the pic exhaust would flow from right to left, through the the cooler I think. ______________________________
Post #386620 12th May 2016 11:55am
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
makes sense
but does the coolant flow through the valve as well as the exhaust gas cooler?
Meaning, is the egr valve itself jacketed with cooling?
Just wondering, as I'll probably get the emulators so will be looking into bypassing the cooling flow through the cooler and valve itself (if it has cooling)
Just as a point of interest, in my line of work I've seen a few cases of corrosion caused by sulphuric acid. Basically water mixing with combustion products (sulphur present in the fuel). For example turbo charger in service water washing, soot blowing boilers and economisers etc. But this was mostly using Heavy Fuel.
Maybe the cause of egr cooler leaks are due to the cooling water being too cold (if not regulated by a thermostat) and condensing the exhaust/combustion products, forming sulphuric acid.
Just a thought
Post #386622 12th May 2016 12:13pm
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
The coolant inlet and outlet marked yellow, I don't know direction, and of interest the have a small thermostat fitted in the end so careful when remaining the hoses, I broke one.
The exhaust flows in the direction of the orange arrows.
The exhaust gas is cooled in the cooler pipe section, and in turn the cooler gas flows through the valve, but there is no coolant going through the valve itself.
I've been told by a tech the hoses can bypass the cooler, maybe some pipes connectors required. If the egrs have been decommissioned it can save a potential problem later.
Post #386640 12th May 2016 1:37pm
Hammer
Egr valve
Post #386643 12th May 2016 1:45pm
Hammer
End of cooler
Cooler thermostat
Post #386647 12th May 2016 1:50pm
Hammer
Pete I'd be looking in these two spots with an inspection camera to try isolate a coolant leak.
Removing a throttle body could maybe also give access to better view the thermo stat housing.
Post #386659 12th May 2016 2:20pm
rar110
Thanks Paul, much appreciated.
I'm back home and have looked at this issue a bit more. I topped up the coolant tank and took it for a run 1 1/2 hrs. When I got back it was down to the previous level but with coolant still pumping around the system.
Last night after it cooled down I topped up the tank again, turned off the AC and let it idle for about 15 min so it was running at normal operating temps. The level didn't move and no leaks on the ground.
I have ordered an inspection camera. ______________________________
Post #388215 22nd May 2016 1:45am
cheezels
If you take the engine cover off, and whilst kneeling on a bar stool, lean over the engine and look down the area around the oil filter, you may see the red crust of evaporated coolant.
I managed this way, but I'm 6'3"
Post #388219 22nd May 2016 5:56am
rar110
Thanks. I looked in those three places as best I could with the torch. No sight of any coolant residue. I'll look again when I get a camera probe. ______________________________
Post #388242 22nd May 2016 11:26am
rar110
The camera arrived today. I had a good look around both sides of the driver side intercooler hose at the manifold end, and behind the oil filter housing, and both EGRs (the inner side). I found nothing except a bit of oil residue between the oil filter and oil cooler (I think it's the oil cooler).
It was idling a bit rough tonight where as normally its very smooth. Also the exhaust smelt a bit strange but I could be oversensitive.
It still uses no coolant while idling. And no sign of coolant on the ground.
Any more ideas? ______________________________
Post #388331 23rd May 2016 1:36pm
Hammer
But is losing coolant on a drive?
Egr cooler leaking internally
Checked oil filler cap for condensation
Check dip stick oil level
Do you have access to a radiator pressure tester?
I'd resist driving till diagnosed
Post #388333 23rd May 2016 2:07pm
rar110
Thanks Paul. Yes level drops back on a longer drive. Around the block no change.
I'll look at those things tomorrow. ______________________________
Post #388337 23rd May 2016 2:22pm
cheezels
Maybe try fast idling to see if coolant goes down.
No water/steam out of the exhaust?
Post #388410 24th May 2016 4:11am
rar110
I will give it a go. ______________________________
Post #388411 24th May 2016 5:18am
cheezels
I was thinking of a way to see if egr cooler(s) potentially leaking.
Maybe take off the inlet pipe from egr to air inlet plenum. See if moisture is present in pipe or plenum.
Pipe is the one with the 'stocking' on.
(Photo from Efors Epic EGR Post)
Post #388412 24th May 2016 6:06am
Page 3 of 4 <1234>
