![]() | Home > Technical (L322) > Rear camera failure! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
the first thing i would do is dis-connect the battery for a while , this might reboot the system .. ... - .- -.
Posted this the other day and did what scarey said to no avail .........
pdt Member Since: 30 Nov 2009 Location: Pirbright, Surrey Posts: 42 ![]() ![]() ![]() |
mick
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
mine has started doing the same in the last couple of weeks , befour that it never faulted once in 5 years i smell a rat somewhere onto no6 Range Rover
Hi guys
Find an indy that can fix it! |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
What ever you do don't shell out that kind of money!
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 ![]() ![]() ![]() |
Apologies for going off topic a little but Elpeede mentioned in his post below about changing the Protocol from PAL/NTSC and vice versa. I'm currently having an issue with the RSE in my Dec' 55 Vogue, one screen is receiving the DVD feed (in NTSC) and the other is stuck in PAL mode which I cannot seem to change.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
What about this? It's seems a lot cheaper than £400!!
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
good spot ![]() |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
OK, so any ideas wher one would find the 'Camera ECU' ?.
Keep it simple - find the camera , check its getting 12v with Ignition on in reverse. (Obviously not with the engine running and Handbrake applied |
