Home > Technical (L322) > 2012 Vogue oil pump problems?
Dave
Ok was all set to pick up the car, but thought I'd phone just to make sure all was well. Its a 5 hours round trip for me. I won't mention the dealer just yet.
Anyway i was given a date to pick the car up, but after calling them, i was told it needed a new ball joint, and that LR didn't have it on the shelf, so it would be a few day's. I was then told all was good and i could pick the car up Monday, again i called to make sure all was well, only to be told that there was a slight oil leak and they wanted to change some gaskets. I was then told that the gaskets were changed but the oil leak was still present, so on further investigation the mechanic noticed a hairline crack in the oil pump, and that would need to be ordered, again not on the shelf. i'm getting very suspicious. I'm not a mechanic, but i thought the oil pump was in the sump, if so how could the mechanic see the crack? any mechanics or people in the know out there? whats your thoughts please.
Changed my mind the dealer is Saxton 4x4
Post #386926 13th May 2016 7:45pm
Gooner687
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Baltic Blue
Tell me more, off down there tomorrow to kick some tyres, i know they have a 'rep' here but wihtout knowing anything more concrete can they be any worse than a main dealer?
Post #386934 13th May 2016 8:18pm
wealy
What car?
Post #386936 13th May 2016 8:43pm
Dave
2012 Vogue 4.4
Post #386937 13th May 2016 8:45pm
mjdronfield
Mine had a massive oil leak down the back of the engine and over the gearbox as the oil cooler was cracked. I know you said pump.... The oil cooler is in the V.... No oil in engine, as its gone into the coolant system. £1097 later all is well.
The garage who repaired mine have done another 4 since mid February.
If that is, indeed, what they mean.....
If you see it, check the oil level on the dash (no dipstick) and check the coolant has no signs of oil in it......
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #386944 13th May 2016 9:20pm
Dave
Thanks for the replies gent's. i have a free app on my mobile that records all calls, i listened to the call and he said a hair line crack in the top of the oil pump, he said the oil was weeping out of it, so no rapid loss of oil. I'll check the coolant to see if there's any oil in it, but how would this be done as the oil would float on top of the coolant, so just looking in the expansion tank would be no good would it?
I'm going to go over the car thoroughly before i part with my cash, any other tips on what to look for please?
Post #386957 13th May 2016 10:02pm
mjdronfield
You'll know.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #386959 13th May 2016 10:10pm
Dave
OH i see lol, hope i dont see this, thanks for your help mate
Post #386960 13th May 2016 10:12pm
Zeppfish
Funny that, my 4.4 tdv8 2012 has just come back from a new oil cooler change, that had a slow weep on one of the fittings. It slowly filled the V up in the center of the engine, and then started pouring down the back of the engine! It looked pretty bad, but had not lost a lot of oil.
When I dropped it off, there was another one in there having the same fix..... Must be a common fault!! 2006 RR sport HSE
Swapped for 2012 4.4td v8 Westminster Santori black with Ivory leather
BEEN SMILING EVER SINCE
Post #387017 14th May 2016 9:46am
Dave
Sorry for the question in advance , but like i said i haven't picked the car up yet.
How do you remove the plastic cover on top of the engine, is it just pull up it off?
Post #387226 15th May 2016 3:35pm
rar110
Just lift it up at the front and pull towards you. ______________________________
Post #387230 15th May 2016 3:57pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I can't recollect if it was on here or another forum but there was some discussion regarding Saxton's customer services and back-up; may be worth investigating and making your own mind up.
We decided to buy our 2012 TDV8 from an official LR dealership and it came with a two-year LR warranty, being less than five years old.
Post #387235 15th May 2016 4:42pm
GraemeS
Australia
mjdronfield wrote:
Mine had a massive oil leak down the back of the engine and over the gearbox as the oil cooler was cracked. ....The garage who repaired mine have done another 4 since mid February.
Do you know if the others failed for the same reason?
Post #387308 16th May 2016 11:24am
Dave
I called them this morning for an update, i was told its the oil pump thats cracked, They have the new one they ordered from LR. but it's a very labour intense job fitting it, i'd really like to check if a new oil pump was indeed fitted, can anyone tell me were the oil pump is on a 2012 4.4, with a pic if possible please
Post #387318 16th May 2016 1:12pm
Mactech
England 2012 Range Rover Vogue TDV8 Buckingham Blue
Just taken my 2012 4.4 TDV8 for service this morning with an oil leak in the V of the engine and oil dripping over the gearbox and exhaust. It has been getting worse over the last couple of months, but I've not had to add any oil.
They just rang to confirm an engine oil cooler (actually its a water/oil heat exchanger) is required but fortunately no water exchanged with oil Smile Only a messy external leak and some oil patches on my garage floor.
My non-JLR warranty will cover the cost Very Happy so I'm just paying for service and MOT.
Seems like the heat exchangers on cars of this vintage are now causing issues, but the cracked oil pump is very rare Sad
......at the moment! 2012MY Range Rover 4.4 TDV8 Vogue...now gone!
2007MY Mercedes C200 Estate 'Albert'
1997MY Defender 90 TDI 'Vera'
Post #387341 16th May 2016 3:38pm
