![]() | Home > Off Topic > Domestic house electrics |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1584 ![]() ![]() |
You're allowed to do your own electrics? |
The basic rules regarding MCBs, breakers, cable thicknesses etc is simple.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
You can run the cables & connect them up, but everything must be inspected, tested and certified by a qualified electrician before the final connection & operation. I agree with the above - a breaker has 2 functions - its a switch that allows you to isolate a circuit - and it's also a 'fuse' to prevent excessive current being drawn. So the 100A would just act as a switch - and the 32A one would still be acting as the 'fuse'. |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 280 ![]() ![]() |
The 100A main switch is not an automatic circuit breaker (I.e. It will not 'trip' on over current in the same way that a MCB would). The 100A rating simply refers to the maximum current that it will pass safely. If you pass more than the maximum rated current, there is a risk of a resistive heating fault occurring.
Yep - you are correct - I need to wake up before posting - it's only a switch, so makes no difference |
It's only house bashing and he seems to have a good grasp of whats required , and it will have to be tested and a certificate issued by a qualified sparky . Australia's attitude of not letting you change a plug is all to do with union job protectionism masquerading as safety. The UK's requirements of wiring are much safer than Australia's yet the attitude to work is a bit more relaxed , funny that ![]() Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
Sorry should have mentioned I am Part P, 17th edition and I&T qualified.
I'd still run it direct from the incoming supply.
I'm sure there are rules on how long meter tails are allowed to be and the garage is 10-15m from the meter.
Nope, although 2 metres is the norm the stipulation is that when over 3 metres you just have to go up one cable gauge. my meter tails are 14 metres and all signed off OK. I just had to go to 35mm from 25mm when I moved the CU during the house extension. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
I should think that 16mm would be more than adequate for the garage. 10mm would be sufficient, especially if you are keeping the 32a mcb in the main board to feed the garage.
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 ![]() ![]() |
I would first look at the cable run in total, how its going to be protected, armoured, trunking, conduit or clipped, also is the garage fixed to the house or a separate building? Range Rover quotes.....
Cable run is approx 8-10metres.
Reply when I'm not so srunk |
