Home > Maintenance & Mods (L322) > Rock sliders and rack
vitola231
Canada 2007 Range Rover Supercharged 4.2 SC V8 Santorini Black
Finally, some time🙂 Rock sliders are all but done! Connect using factory side bar mounts and go overtop existing plastic rocker guards, no cutting drilling etc. Just need to laser out front piece of rack with lexan covered cutouts for lights and can prime and linex all this stuff Thumbs Up front and rear bumper guards next!
Post #387157 14th May 2016 10:12pm
Hi,
Looks good, can't see what they are made out of but my rock sliders are 80mm x 40mm x 4mmwall box section with 6mm plate welded to original sill, tree sliders are 50mm x 4mm tube....
I've bent mine whilst rockcrawling so I would be careful if I were you.... Thumbs Up
More info here http://www.fullfatrr.com/forum/topic31680.html Pete
-Click here for Thread-
Post #387174 14th May 2016 11:58pm
vitola231
Thank you Very Happy
They are pretty light. 1/8" plate folded is the base then schedule 40 pipe. I made them just so that if I hit something I can stop and not damage body, maybe should call them sill protectors. I wouldn't slide over rocks or logs with them for sure. Wanted to leave oem plastic etc inplace. Think I will line them with rubber so not to damage the oem plastic.
I've hit the age where I drive by sound because can't see so well anymore Very Happy
Post #387176 15th May 2016 12:08am
vitola231
Rack is mainly only to hold this canoe so pretty light again.
Post #387177 15th May 2016 12:10am
You should be fine then... Thumbs Up Thumbs Up
Mine bent when I fell off a two foot lump of rock and the whole weight hit the rear of the sill... all 2829kg of it.... Rolling Eyes Pete
Post #387178 15th May 2016 12:16am
vitola231
Just read your thread. I was originally going to pop out those plastic rivets on underside of factory sill protectors and insert thread rivets and make stand off pieces but its a lot of work if retaining the plastic. I should pop them off though and spray in cavity wax like you did, just a smart idea, and check for rust but kind of afraid to look. I had a metal shop convert my drawings to CAD and form up the plate, I should really convert it to PDF and post it.
Just read through topix land rover at bull bar mounting, I see there is something behind the bumper skin to bolt to. They drill holes through bumper which isn’t a big deal really or I can maybe make brackets. Time to buy more pipe Smile, I already have my design. My only worry now is wether the rack will be quiet or noisy, guess time will tell. And mounting hight, the rack itself is 2” tall and I made it so it could mount tight to roof or hover above, i’m thinking like 1/2” above.
Your in England, wish I was on that side of the planet! Thinking of ancestry residency to England, grand mother is British and have great aunts there.
Post #387232 15th May 2016 4:26pm
vitola231
Post #387277 16th May 2016 12:41am
vitola231
Post #387430 17th May 2016 2:08am
