![]() | Home > Maintenance & Mods (L322) > FBH set to come on daily. This ok? |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
I don't think it really has any impact on the performance of the heater, but it may contribute to drain the battery. 2005 L322 Vogue Gold gone
boatsandy1966 Member Since: 05 Dec 2015 Location: nr pagelsham essex Posts: 162 ![]() ![]() ![]() |
don't think it comes on once temperature is to high even when set 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
It will only come on if various conditions are met. I don't think it will come on now, even if set..... 2011 Range Rover Vogue SE 4.4 TDV8
Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128 ![]() ![]() ![]() |
^ as above have said.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
I believe 15 deg C is the magic number - above that ambient and it wont come on (I think) |
it has to be less than 5 degrees for the fbh to work.. ... - .- -.
Sorry Stan I bow to your superior knowledge but even 6, 7, 8 etc degrees is cold and you might still want to heat the car up.
It was on at 0730 am yday when I was washing the car. Didn't note temperature but wasn't cold out.
i just got that info from the wiki Ade... ... - .- -.
