Home > Maintenance & Mods (L322) > Anyone know what this is?
Waynetab
United Kingdom 2004 Range Rover HSE 4.4 V8 Galway Green
And what it does?
Washing car today and found it hanging loose under the front radiator grille. As you can see it is cracked,
and untill I know what it actually does I have no idea if working or not.
Post #387517 17th May 2016 3:35pm
Waynetab
Maybe I should have said its a 4.4 petrol 2004
Post #387562 17th May 2016 6:32pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Doesn't look like anything original. Couple of things it could be:-
1) Aftermarket Digital TV antenna
2) Tracker Device Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #387611 17th May 2016 10:30pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
It obviously slides in to some kind of bay (see arrow) so look for that bay and where the cables are going.....sorry I am a
non tech. Embarassed
Post #387613 17th May 2016 10:33pm
Waynetab
It bolts to a plate above the front tow eye and I am guessing that the arrow is there to make sure it is pointing ahead?? Doesn't slot in to anything.
Also no screens in the car, its a HSE.
Thanks for suggestions
Post #387632 18th May 2016 7:38am
Edfors
Sweden 2008 Range Rover Vogue TDV8 Alaska White
Could be a speed trap Laser/Radar warning receptor, if this is the case it's probably accompanied by a buzzer and/or a LED warning light inside the cabin or something like that. Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #387634 18th May 2016 7:49am
Waynetab
Think you got it!!
There is a tiny red led just left of the binnicle, always wondered what it did. Never seen it flash or heard a buzzer so presume its no longer working. Would have been handy
Post #387635 18th May 2016 7:58am
It's a tracking device your other half had fitted..... Whistle Whistle Thumbs Up Pete
Post #387640 18th May 2016 8:22am
Waynetab
Thats a scary thought Rolling Eyes
Post #387644 18th May 2016 9:00am
Only if you've been somewhere you said you weren't Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #387645 18th May 2016 9:02am
QR barcode scanner should give the answer
Post #387647 18th May 2016 9:29am
Waynetab
Thought the barcode scanner was a great idea, sadly it comes up as a "A312498"
Exactly what it says under the barcode lol
Post #387652 18th May 2016 10:24am
Waynetab
Took it apart and to me looks like it could be a radar detector.
Going to give it a go with contact cleaner and toothbrush, reassemble and see what happens
Post #387653 18th May 2016 10:40am
