Home > Technical (L322) > Sharkfin
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Sharkfin
Hi guys,
What's involved in replacing the Ariel ??
Does the cover " just " pop off??
Mine has a crack in it and I'm sure it's letting water in! ie, when it's raining my sat nav has a mind of its own, and radio reception isn't great!!!
Thanks David 2014 vogue se
Post #387692 18th May 2016 3:24pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Unfortunately its not as simple as just popping it off - you have to take some trim out and unbolt it to then be able to unscrew the case- fortunately there is a write up that Super8 did a couple of years ago (although its mainly about replacing the GPS receiver but the action to remove the fin is covered - its about half way down this post
http://www.fullfatrr.com/forum/topic17777-15.html and there are some pictures later in the post.
Hope that helps Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #387700 18th May 2016 4:42pm
chefkenmore
Great response !
All the info I need!
I'll get someone else to do it Rolling with laughter Rolling with laughter Rolling with laughter
Thanks for the link
David 2014 vogue se
Post #387702 18th May 2016 4:53pm
sako243
Do what I did with the 110's snorkel an drive into the tip without waiting for them to open the barrier...
Embarassed Ed
Post #387756 18th May 2016 10:19pm
