![]() | Home > Off Topic - Other Cars > The start of it i guess |
The other day the wifes sport electronic hand brake made one helluva noise when she went to release it , so happens her rear brakes locked on for some reason , car was uplifted by LR Assist , telephone call today from LR so now she has to fork out £700 for to rectify the problem ... |
Surely that would be warranty Mick? |
Fraid not Dom they have said no , i thought it would have been covered |
She has only used it a few times Al as she just leaves it in the P position |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6836 ![]() ![]() ![]() |
As do I Mick, best way to avoid unnecessary expense |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
I disagree, there is an electric motor down there that needs to be worked. If you don't use it regularly it will seize.
I disagree with your disagreement. I NEVER use it, so it won't ever be an issue! |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
On the 322 does it not automatically engage when you switch the engine off? Mine does - sort of a fail safe thingy.
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
It may well be possible to fix it - take a look here: http://www.disco3.co.uk/forum/topic91299.html |
Just found out what the actual problem was when i called the service manager , the rear linings have actually came off the rear brakes causing them to lock
So let me get this straight Mick, a newish car and the linings have come off the handbrake shoes, right? And the warranty said no, right? So it's not wear and tear, it's a premature failure of a component and LR warranty are full of shaving cream.
Alan.m3
Well it passed a few weeks ago |
Sorry to read that Mick... Wish her a speedy return |
