![]() | Home > Maintenance & Mods (L322) > Making your power steering ligher? |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2713 ![]() ![]() ![]() |
I would be contacting cam tech Craig, if anyone knows... |
Dobbo Member Since: 10 May 2016 Location: Shropshire Posts: 3 ![]() ![]() ![]() |
Is he a member on here? |
Site sponsor mate: http://www.cam-tech-landrover.co.uk/ |
Thanks 👍 |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
The steering rack has a servo valve on it which I believe can control the amount of assist given. Its subtle but the steering goes lighter at very slow speed and firms up at higher speeds. I notice it on twisting a roads a bit.
The Servotronic valve is controlled by the body Processor Module and so making the steering lighter or just light all the time would require rewriting the hardware's program , I don't know about you but I would consider that beyond what mere mortals can achieve , if you bypass the valve the system resorts to a failsafe function which is quite heavy but still assisted. 2008 MY Supercharged
I'm not sure that the system is closed loop in that the controller doesn't sense whether the servo valve is responding to the signal is being sent. if that were the case, then in theory you could intercept the control signal and replace it with one which gives lighter steering. no programming required.
