Home > Technical (L322) > KEY NOT TURNING FIXED BUT FOR HOW LONG??
dingg1
This has recently started on my car (missus moaning she can;t start the car due to key not turning)
anyhoo a search finds this is quitE a common problem and a few here have suffered this pain also.
there appear to be two fixes
1 drill hole in steering column lock casing and lubricate with wd40 or such like
2 fit fused switch to fuse 18
I have went and drilled the casing of the locking mechanism and lubricated with wd40 and the problem has been sorted (so far )
this leads to my question for those who've carried out the same job
how long does this fix work for in general ??
tia
ps link for place to drill http://www.blackbox-solutions.com/photos/L322lock.pdf
Post #388052 20th May 2016 5:25pm
mr_spock
There was a long thread on another forum in which a guy opened the column ECU which contains the lock solenoid. The magnets within had broken up, and he got some new ones. I think Haylands is trying the same. Should be a permanent fix.
Post #388056 20th May 2016 5:39pm
dingg1
yes I recall reading that thread , I'm hoping that in my case the lube will have sorted it .I have tried about 50 key operations and it hasn't failed to operate correctly once since copious amounts of wd40 were squirted in there
Post #388061 20th May 2016 5:49pm
