![]() | Home > Technical (L322) > '02 L322 4.4 L V8 Coolant issues/possible head gasket/HELP! |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
Hello all.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
They probably don't want to do it because of the Vanos system and the special tools and knowledge required, if you shop around I'm sure you'll find someone who will do the head gaskets...
Thank you Halyards, oddly enough I have just been admiring your post about your winch install!!
Haylands** |
Lots of folk still think the M62 engine had the nikasil treatment and you can't do anything with it...
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
This is almost exactly what happened to mine. I was also told it may be a head gasket, without a hydrocarbon test.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
mr spock, that's very logical....
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
Unless you know and trust this garage I would get a second opinion. Sounds all too quick to opt for the biggest job to fix it. |
Sorry, I just re-read your original post and saw you already have a new rad and expansion tank. I'd be looking at the fan clutch as above. |
Gentlemen, Thank you very much for your swift and detailed responses!
So I went to the garage this morning who are adamant that it is a head gasket.
Topping up coolant is not bleeding. It could be leaking from the coolant pipes on the back of the engine or the valley pan gasket, although I'd expect to see some coolant below. Can you ask how much they added, and how? Did they remove the bleed screw or just add coolant? Seriously, mine went through a half a litre each time I ran it. |
Hmmm I get what you are saying but I kinda get the impression that they have done the following:-
