![]() | Home > Technical (L322) > Few questions as a new owner! TD6 HSE |
| Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481
Hi all,
| chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130
Maybe change the torque converter if it's high mileage and hasn't been done. On the TD6 they go without warning and take the box along with them.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Pleased to hear you have your own code reader now |
Thanks for the info guys, much appreciated!
| gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077
Hi stacker, when your cruising at say 60mph, is the rev counter reading about 2,000 rpm, if it is then your in tc lockup, any higher say 2500 -3000rpm, the tc is not locked up. As an observation mine doesn't particularly roar, but is chipped, which I believe makes the gear changes better.
Thanks again for the replies.
Good news if there are no fault codes logged.
I'll keep my eye on it!
Yes that's correct. |
| All times are GMT |
