Home > Maintenance & Mods (L322) > Where's the logic?
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Where's the logic?
Now I'm not complaining as its fixed but...
Where's the link? Other half told me today on journey home the "Check Brake Fluid" light came on... Then "HDC Inactive" then "Suspension inactive". When I got my head outta my hands I went out and tried steering wheel reset. Turning on and off etc but messages still came back.
Topped up Brake fluid reservoir with 200ml (shocked how low consider no leaks and good pads) of brake fluid and all clears itself and all warnings gone!
How does Brake fluid level effect air suspension and Gearbox!!
Confused
Tel Accept, some days your the pigeon, some days your the statue!
Post #388183 21st May 2016 7:11pm
mzplcg
You could also ask how a humble Stop/Tail bulb could bring the mighty Discovery to its knees, but it can. Confused
Post #388184 21st May 2016 7:16pm
Boydonegood
Haha really? No way! Rolling Eyes Accept, some days your the pigeon, some days your the statue!
Post #388185 21st May 2016 7:21pm
mjdronfield
HDC uses abs, so probably disabled if fluid low....
As to suspension, no idea.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #388186 21st May 2016 7:27pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
According to Storey Wilson (RSW Allcomms) , the ABS and Air Suspension computers are closely inter-related so a fault on the ABS system will almost always trigger an air suspension fault warning too. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #388198 21st May 2016 9:39pm
Lost for Words
Yep, but it is logical; bad bulbs cause electrical noise on the brake circuits, which in turn upsets ECUs. It can happen on other "premium" vehicles too. Thumbs Up
There are always all sorts of faults that can trigger each other because of the way the systems are designed to work together. Easy to see it as a PITA, but it's what makes LRs work so well both off and on road. Smile Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #388233 22nd May 2016 8:39am
I would also be removing the covers on the LHS underneath to check the condition of the brake pipes (that is the tank cover and the flat covers on the long run from front to back) If your pipes have not been changed they are likely to be quite corroded and leaking. 200ml is a lot of fluid to lose so keep an eye on the level.
What everyone else says is correct, all the ECUs are linked together in a chain, so if one thing fails, it kicks up errors elsewhere for safety reasons. Therefore if brake fluid is low, you will get an ABS fault, an HDC fault, it will lock down the air suspension (EAS) and this will also get a fault logged in the LCM. Once the issue resolved, check then clear all faults with diagnostics, then check a couple of days later for returns. .
Post #388238 22nd May 2016 10:30am
