Home > Technical (L322) > Rear space
Realist
Wales
Rear space
Guys anyone.
I'm looking to collect a marine tank this weekend in the FFRR and need to know if the following will fit in the rear with the seats down.
I'm unable to measure as the wife has the car in work now and I need the info so I can let the seller know.
The tank size is: L37XW22XH24
The base is: L38XW22XH35
Both of the above are in inches.
I'm hoping the will fit side by side ie 22" tank width with base 22" so that's a total of 44" width and a length of 38" and height of 35".
Can someone let me know urgent please, even if its a guess. Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #388396 23rd May 2016 9:56pm
I would have thought they'd fit - and wouldn't put them side by side, but would put them sideways so no stress on the middle of the tank.
I got a 42" wide tool cabinet in my L405 and it doesn't feel any wider than my L322 Thumbs Up
I would have thought length was more like 60"
Post #388400 23rd May 2016 10:06pm
Realist
Wales
So instead of putting them in side by side they would fit length wise arch to arch 38" max there about? Range Rover quotes.....
Post #388402 23rd May 2016 10:10pm
My L405 boot is about 44" wide
With the seats down, I would guess at 60" long
Not sure on the L322, but would expect 38" would be OK - hopefully someone can measure & confirm - but longer than it is wide with the seats flat Thumbs Up
Post #388404 23rd May 2016 10:16pm
fisha
The combined 44 width should fit. An 120cm wide plywood sheet just doesn't quite fit by a few of cm. height might be more of an issue possibly. It'll be close. put the Base in first. V8 or else ...
Post #388532 24th May 2016 9:56pm
Realist
Wales
That's what I intend to do, base first then tank wrapped in bubble popping squeezing annoying wrap.
But its a 4.5hr drive up and back so a early start and hope to get back mid afternoon. Range Rover quotes.....
Post #388534 24th May 2016 10:05pm
Realist
Wales
Well thanks guys,
Drove from Bargoed South Wales to Rhyl North Wales, collected the tank (Yes fitted a treat) and drove all the way back.
The car didn't miss a beat and mileage wise its great and shifts as well.
Regards Range Rover quotes.....
Post #389121 28th May 2016 6:25pm
Post #389122 28th May 2016 6:30pm
