![]() | Home > In Car Electronics (L322) > Sat Nav Update 2011/12 L322 £321.60 !!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35728 ![]() ![]() |
@f4rrs, yours is hard drive based.... ... - .- -.
Yeah I agree with Stan that I prefer a good in car system with maps up to date (for a reasonable price and not highway robbery). I don't like sticking any aftermarket stuff in but clearly JLR don't give a hoot about charging ludicrous amounts for map updates AND not getting maps for most of the world (for example I can forget maps for the part of Asia that I live and travel in !!!).
Dear god my 2005 06MY ff is running 2015 maps and a lot less money than being charged above!!!
indeed Will |
Is there no USB port on these ones at all or does it all get done thru the dealer tool?
there is an usb port for the portable audio...i cant find out how the dealer actually does the update whether via the obd or a hidden firewire post somewhere.. ... - .- -.
If it's actually taking more than 30mins it can't be via USB and would be the OBD port id guess FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
On the later models the navigation update is apparently done using a USB stick. They can be bought straight from Navtec even if my info is correct.
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
The dealer said it takes two hours to update after they have purchased a licence and logged in.
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
^ The dealer I used quoted ½ an hour.....it took longer because the download failed near the end so had to be re-started. Still the same price. I do hope you didn't mention the other dealer by name. |
That would ruffle a few feathers and likely mean they just up the price for everyone else. Although for half an hours work it's not bad money at all! I bet they already had the update downloaded and it's just the activation of it that requires login and then upload to the onboard hdd/car unit FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3836 ![]() ![]() ![]() |
The absolute ultimate solution has got to be a Bluetooth iid tool that links with a smartphone to give full display on the inbuilt screen. Not only would you know how to get from A to B, but you would be able to read the fault codes when you you break down on the way !!!.
