![]() | Home > Technical (L322) > Interior lights, 2010 FFRR |
interior lights only come on when a door is open so i dont understand your reasoning to be able to dim them.. ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Merc’s don’t use interior lights in daylight hours Stan... The OP is asking if RR can do the same thing...
Dale Member Since: 26 Mar 2016 Location: Tuusula Posts: 17 ![]() ![]() |
Darn, thx anyway.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
If you keep the interior light switch pressed in for 3 seconds they will be deactivated. You will have to repeat the procedure to get them to work again. Not exactly what you wanted but may help....
Thank you, this is good to know.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Dale
good tip Mark |
Have to start saving, then.
