![]() | Home > Technical (L322) > TDV8 Engines. Are they the same? |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Yup. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
Of a certain age..... the Sport only had the 3.6, the FFRR moved on to the 4.4 |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
Cheers lads! That's all the info I need. Hopefully will get an engine sorted soon! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
I would be very surprised if the engines were the same 3.6 unit in both cars! They certainly run different ancillaries.
Would a lot of that be bolt on items? Could I bolt my various additional components on. |
If your after a 322 replacement... I would think a 322 replacement is what you need sir... A 320 engine could mean changing heads and every sensor etc etc over between engines! That becomes VERY expensive! Let alone finding your engine may have tapped holes a 320 engine does not???
That rules out the Sports so! I'll have to keep hunting. It's hard work! |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2712 ![]() ![]() ![]() |
If you're really stuck, I do have a contact who might be able to help, a recently retired GM for a rather large salvage operation, there is an outside chance at best, happy to call him. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2733 ![]() ![]() |
According to my copy of MCAT the 3.6 blocks, heads and inlet manifolds in the L320 and L322 have the same part numbers. Obviously the sump is different. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1849 ![]() ![]() |
Basic engine is the same, sump, wiring and ancillaries are all different |
Hey Mr. Tee, That would be great. I could PM you my mobile and you could chat me first if you like?
Aye, go for it, he might be abroad just now, can only ask. |
