Home > In Car Electronics (L322) > Fleebay rear camera replacement FFRR
dvb247
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Bonatti Grey
Chaps Thumbs Up
Would one of you kind fellows give me a flyby item number or link of a replacement rear view camera?
I've read the WIKI on the FFRR MY2006 rear cam repair and the link to the £13 camera has obviously ended and I'm not so sure about which one to choose? some now look angled which won't work!!
Post #380367 1st Apr 2016 7:48pm
dvb247
Ive purchased this one, I'll keep you posted with the results
eBay item number:252071240797
Post #380477 2nd Apr 2016 8:52pm
HGv driver
Wales
yes please do as mine need changing it works fine but the picture is upside down
on dear that didnt work too good now side ways on,but youy get the jist
Post #380731 4th Apr 2016 4:57pm
STU TDV8
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
When i put my range rover in reverse the screen is black ? ...Does the camera you guy's are talking about fit into the standard casing ? . What is the item number as the one above has finished ?..
Post #380777 4th Apr 2016 10:52pm
dvb247
Sorry, no luck getting it working, I managed to strip it all down and could see an easy fit getting the new camera glued inside the original rear camera casing but failed miserably on the wiring, even tho its only 4 wires I could not get it to work.
Big Cry
Post #386968 13th May 2016 11:03pm
Angus_bull
United Kingdom 2006 Range Rover Vogue SE 4.4 V8 Java Black
I bought one the same as item eBay Item No. 141918317810 and the end part unscrews allowing the metal ring to be removed.
I then used small snips and a file until all of the lip was removed meaning the camera was the same diameter all the way along. This then fits perfectly into the housing.
The wiring requires a bit of soldering. The red and black wires on the original loom are positive and negative and the other is the video coax. If you snip it close to the original plug that goes into the old camera pub then you can solder it to the wires supplied in the kit. Use a multimeter to determine the centre wire on the original plug and solder that to the centre wire on the yellow plug the remaining one is the negative for the yellow plug.
Before assembling the camera, test it and make sure the camera is orientated in the holder correctly i.e the picture is not upside down then put everything back together. I chose not to seal the camera holder up but ended up with condensation in the holder.
I'm also not happy with the guide lines as they look funny when you put it in reverse as the picture is zommed when you stick it in reverse which looks funny. Mine is also pointing too much downwards so I have bought a new camera without the guidelines and I'll be taking it apart in the next few weeks again.
I can take loads of photos when I do it if this helps.
Post #387169 14th May 2016 11:28pm
dvb247
Please do, specially photo's of the soldered wires, then I will have another go, fingers crossed and thanks in advance!! Thumbs Up
Post #388533 24th May 2016 10:00pm
STU TDV8
How did you go about the co-ax cable ?..
Post #388557 25th May 2016 7:57am
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Hi Guys,
I bought one and its got the extra (short) red wire going into each end. What do you do with that?
Confused
regards
John
Post #388679 25th May 2016 11:44pm
Angus_bull
I'm working offshore for another week but if you take a photo of the stripped wires on the original loom, I can mark them up for you.
Post #388825 26th May 2016 6:59pm
