![]() | Home > Technical (L322) > Hi guys |
| boatsandy1966 Member Since: 05 Dec 2015 Location: nr pagelsham essex Posts: 162
dam id be backing that hope you get sorted 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Get the battery tested. These cars are notorious for needing a large and well charged battery. If it's the original chances are it's below the required condition for a FFRR and if it's been replaced at some point it may have been with a battery which doesn't have the required CCA or AH ratings.
| missbelle Member Since: 22 Jan 2016 Location: west sussex Posts: 13
Hi guys thank you for getting back to me so quick battery has been tested and sits at 14.4.... even after sitting for 2 weeks she turned over as quick as expected... any other ideas lol |
| Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267
It is back to diagnostics am afraid .! |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
I'd suggest to start checking all the posts on air suspension here and see what could be wrong. Sorry to not have better news. Start with the simple stuff, listening for any leaks (does it lose height after standing for a while, mine lowered itself a little bit before the front suspension airbag really gave up). Check if all hoses are fine.
| JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833
I dont think the compressor is at fault as when it was going up and down it was much faster than my L322 which i wasnt impressed with, I think we will try my brand new Bosch battery in it over the weekend. Just to add insult to injury the cable from outer door handle to lock snapped yesterday om Missbelles car !!!! God I hate that car. One day your life will flash before your eyes......................................make sure yours is worth watching!
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Worth a battery disconnection procedure, then a lock to lock on the steering to clear the lights, that should reset everything.
Tried Bat disconnect both leads and touch ends together, doesnt appear to register a fault code on my snap on scanner which picked the wheel sensor fault up straight away. One day your life will flash before your eyes......................................make sure yours is worth watching!
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
I assume you have checked the air suspension fuse?
ERR yes of course we did or will in the morning |
| All times are GMT |
