Home > Maintenance & Mods (L322) > tips for winter
Page 1 of 4 1234>
tips for winter
thought i might start a thread for members tips to help prevent winter woes with the FFRR..
i found my door lock would not close after opening it yesterday so a squirt of wd40 into the door lock mechanism solved it this morning.. ... - .- -.
Post #38920 24th Nov 2010 1:30pm
Vogue
long ratched strap - if all else fails can be used for self recovery or to tow you out.
Folding shovel
Bottle water - either to drink or for washer
small army stove or similar
Post #38923 24th Nov 2010 1:34pm
Fox
Keep a warm blanket in the car. Handy if you have a problem.
Post #38930 24th Nov 2010 1:42pm
Vogue
or get lucky Thumbs Up Laughing
Post #38932 24th Nov 2010 1:43pm
Re: tips for winter
Did that last year and it worked all winter! Original problem was the door stuck open or closed due to frost. WD40 immediate cure best applied with the straw direct into key slot and then onto the mechanism. Thumbs Up
Post #38934 24th Nov 2010 1:47pm
Next thing you need is a set of Vredestein Wintrac 4Xtreme tyres for massive grip in the snow and they look great too....(www.camskill.co.uk) Thumbs Up
Post #38936 24th Nov 2010 1:48pm
Re: tips for winter
tip confirmed... Thumbs Up ... - .- -.
Post #38937 24th Nov 2010 1:48pm
tip from happymadison1978.
to stop door rubbers sticking....
Einszett Gummi Pflege: rubber seal protectant and feed works well on the felt too, comes in a shoe polish style applicator and only costs about £6.
it can be found on ebay for £6.95 plus £1.95 delivery ... - .- -.
Post #38939 24th Nov 2010 1:50pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
If there is a heavy frost, then run a credit card along the top edge of the door before you open it, as sometimes the rubber seal will weld itself to the roof of the Range. If you don't do this, then the seal can stick to the roof and pull itself away from the door as you open it, which will permanently damage the seal.
Post #38943 24th Nov 2010 1:54pm
dan_uk_1984
WD40 - worst thing you can put in a car lock.
It cleans all the graphite powder and grease out - hence why you use WD40 as a de-greaser. Short term gain, but long term pain.
Lots of stuff on the interwebs about it.
For door seals I use this: http://www.camskill.co.uk/products.php?pli...&rs=gb
Just spray round all the rubbers weekly after washing. Makes the door shuts shiny too if you wipe over with a rag.
D
Post #38946 24th Nov 2010 1:58pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Mobile phone....
Post #38951 24th Nov 2010 2:03pm
any alternatives dan? ... - .- -.
Post #38955 24th Nov 2010 2:08pm
Richcl
I used to use vasaline on door seals, then read somewhere that wasn't a good idea....
Post #38957 24th Nov 2010 2:12pm
Thanks for the tip re WD40 Dan I guess its just a quick fix if you really cannot shut the door a position I was faced with!
Post #38960 24th Nov 2010 2:18pm
dan_uk_1984
Graphite or Teflon powder for lube.
In general you shouldnt get water in the keyhole, if you do, you're doing it wrong!
Post #38965 24th Nov 2010 2:52pm
Page 1 of 4 1234>
