![]() | Home > Maintenance & Mods (L322) > FFRR Service |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 ![]() ![]() |
Guys,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35685 ![]() ![]() |
insufficient oil in the engine me thinks......check the level and see if theres any in there..... ... - .- -.
Should be I hope it's just been changed within the last 2 hrs.
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
He wouldn't be the first person to put new oil in with the drain plug on the bench |
Just checked oil it's clean and on the full mark 😡
Is it safe to drive with the above message showing up. Range Rover quotes.....
Took the car for a little drive and as soon as its driven the message disappears but as soon as you stop the message pops back up on the dash. Range Rover quotes.....
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1822 ![]() ![]() |
Replace the oil filter with an OEM one, and make sure it's fitted properly |
The filter is by Britparts all the cars filters was changed as a service pack.
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Britpart? Get rid of it quickly! Visiting from DISCO3.CO.UK
Thought Britparts was ok? Range Rover quotes.....
They sell some decent stuff, but they are known as "$hitpart" for a reason and I would never use anything but an OEM oil filter. |
Me not machanical minded so where is the sensor!
Take the filter out, and replace it. Doesn't matter if it's tight |
