![]() | Home > Maintenance & Mods (L322) > FFRR Service |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
RAVE says the sensor screws in to the underside of the filter housing. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
What Mikey said, don't drive it, only buy genuine filters and get it changed ASAP...
Cut one open and have a look, they are nothing like an original one, heard of others having the light on after using one so I presume it prevents oil flow somehow, never looked too deeply into it as I'd never use one anyway.... Can't see the point of saving £10 on an oil filter when a new engine is several thousand.... Pete
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 ![]() ![]() |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1844 ![]() ![]() |
I would recommend a new garage for your next service. The nipple gets crushed from incorrect fitment. Seen it many times, with expensive outcomes every time... |
Glad to hear it's fixed! |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
Be good to see a photo of the crushed nipple thingy - is this a easy mistake to make when changing the filter and can it also happen on an OEM part? 405 AB exec seats Baltic and Cirrus
It could happen on any make of filter and shows you how important a clean unblocked filter is. Range Rover quotes.....
TDV6 engine, but similar design of filter
There is a hole inside the filter housing to locate the nipple into, then the filter cap screws onto the housing If you push the filter into the cap, and screw it in, this is completely wrong and causes the above to happen, and can happen with any brand of filter. But Britpart filters are best avoided, IMHO ![]() |
I'll get a better filter tomorrow cos I reused the old filter for now.
This was the aftermath of said TDV6 with incorrectly fitted oil filter...
Bloody hell. Range Rover quotes.....
