![]() | Home > General (L405) > adaptive xenon lights (AFS) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
put your vin into here and it will give a build sheet,
JMDT Member Since: 10 Jan 2016 Location: Suffolk Posts: 60 ![]() ![]() ![]() |
Thanks Stan. My build sheet is not showing on vindecoderz... The vehicle is new so I think not yet loaded.
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 280 ![]() ![]() |
Park facing a wall and turn the steering from side to side. It should be obvious whether or not the beam follows the wheel. |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
Not too sure I'm on the right track here but if it's what I think you are asking I'm not aware of any visible difference but they do need to be set via the driver menu feature. That way you'll notice them go to full beam automatically, provided there's no on coming traffic and will illuminate around corners when driving slowly and turning. |
Thank you ... All makes sense and at moment they don't move when I turn. One to check out with my dealer this weekend ... |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Paul J. They don't work when a vehicle is stationary.
The menu that Basilfaulty is referring to is for the high beam assist function. But that's a good check, I think you have to have adaptive headlights if you have high beam assist. |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
No, I have High Beam Assist and no adaptive headlights. |
WOW. |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1172 ![]() ![]() ![]() |
High beam assist is standard however adaptive and assist is a £315 option on the AB.
£315 ? Its a must have at that cost! - Come on LR - make it standard. |
Mcnallykev Member Since: 19 Jul 2015 Location: Lanark Posts: 172 ![]() ![]() ![]() |
I have adaptive that doesn't test on start up but works fine. I do not have high beam assist though. Is it really standard? |
Don't think high beam assist was on the 322? |
That'll teach me not to read the title! My Mate has a 322 and has high beam assist. His is well specced though. |
