![]() | Home > Technical (L322) > Rear Near Side brakes binding |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
depends how handy you are with spanners you can either remove the wheel and then the caliper and use grips to push the pistons back in and then put the caliper back on and operate the brake repeat a couple of times to see if it fixes the problem if not you either need a rebuild kit or new caliper or if you are not that handy get a mobile mechanic to do it either way you can't drive it L322 2008 vogue
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 492 ![]() ![]() ![]() |
Thanks Ivor..
Just replaced all my discs and rear pads last weekend that was fun saved me a fortune on parts and labour my local up here give me a free check over once a year to try and get work lol the girls know I do my own apart from servicing L322 2008 vogue
Okay, calliper was locked on...two new rear discs a calliper and pads! £££ |
I picked mine up for around £60 for the discs and about the same for the pads easy enough job just the handbrake adjuster is a pain to see L322 2008 vogue
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8083 ![]() ![]() ![]() |
Time to talk to Dan |
The rear calipers are a weak point on the FFRR and usually go close together, so good choice to replace both, pity that you had to do it so shortly after discs and pads though. Hope that you will have many more problem free miles. MY 2010 5.0 SC Galway green and sand interior!!
