![]() | Home > Maintenance & Mods (L322) > Retractable Side Step, Metal step broken. |
Eric Cartman Member Since: 05 Nov 2014 Location: Dublin Posts: 108 ![]() ![]() ![]() |
Got the arm back in , its holding for now, is it possible to just buy this section of the step bracket ?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16365 ![]() ![]() ![]() |
Usually the car has been jacked up and down a couple of times, the EAS has self levelled a number of times (lowering itself each time) the car has then started and either the left side door was not closed correctly or the step didn’t retract before the car was driven (maybe off the ramp?) and the lowered suspension coupled with the non retracted step you cet a bang as the front of the step hits the top plate of the ramp and |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
wot Craig said. more or less the same thing happened and I ripped my nearside step clean off.
boatsandy1966 Member Since: 05 Dec 2015 Location: nr pagelsham essex Posts: 162 ![]() ![]() ![]() |
id be talking to the dealer for sure 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1469 ![]() ![]() |
I sympathise as I have experienced this sort of thing with previous cars. You leave them to be serviced, repaired or even just MOT'd and when they come back there's a scratch, something missing or just doesn't run as it should |
blimey your lucky son |
