Home > Maintenance & Mods (L322) > Main Fuse Board - FFRR L322
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Does anyone know on the MAIN FUSE BOARD PASSENGER COMPARTMENT:
Their are BLANK Live fuses ( no's 4 /13 / 18 / 26 / 35 / 53 / 54 / 59 / 60 ) in the Owners Handbook
The vehicle is a 12 MY - 4.4 TDV8
I am after one of these that is LIVE when the vehicle is locked.
I have chosen Fuse 60 at present - but when the car is locked it shuts off the circuit. ( so this is no good )
What I am after is a LIVE Blank fuse - that can draw 0.02Amps - for a Passive Camera that's mounted in the front window
I have the female fuse adapter that fits into the Black fuse socket similar to below pic
BUT IS THERE A LIVE ONE ?????
Where can you get LIVE current ( Fused ) when the FFRR is locked and stays live for 48hrs
Thanks in advance to anyone that answers Thumbs Up
Post #389492 31st May 2016 11:37am
possibly fuse 9, electronic parking brake , should be active maybe
or fuse 17, keyless entry ? ... - .- -.
Post #389493 31st May 2016 11:44am
or you can tap into the fusebox in the engine compartment [box on left side] and run a feed into the cab.. ... - .- -.
Post #389494 31st May 2016 11:47am
EmiratesA380
Hey Stan - TOP MAN as usual
Got it sorted this afternoon - took a supply from the "Battery Backup sounder Fuse No 36" - the fuse was 5 Amp - current draw added is only 0.2 amp
Fuse no: 36 is live all the time ( 5 Amp )
Note to anyone reading this
change all your fuses every couple of years - some as the above FUSE have a current running through them 24/7 and they can get tired/old with current running in them - a new fuse will have new a life span than a tired old one. FACT
Thanks Stan for coming back - appreciated.
Post #389908 2nd Jun 2016 9:17pm
Thumbs Up and i appreciate your 'comprehensive' posts... Wink ... - .- -.
Post #389918 2nd Jun 2016 10:05pm
Mine are all 14 years old, I've had it over two years and none have blown... I did pull them all one at a time just after I got it to check them, some had evidence of poor contact with the fitting and I guess a resistance had built up as some pitting was evident, I just cleaned them up and turned them over... been fine since....
My wallet has got very stiff since I moved up here and became a Yorkshireman... Laughing Laughing Pete
-Click here for Thread-
Post #389919 2nd Jun 2016 10:10pm
EmiratesA380
Hi Haylands
I went to Halford's some time ago and purchased 8 boxes of the mixed mini fuses - when I am flying over you way will drop a box off
I know how tight you Yorkshire boys are !!! - Just have a look at the Tea you serve - enough said
Post #389969 3rd Jun 2016 9:17am
Weegie
"Tea"? I thought it was for road maintenance. Rolling with laughter Rolling with laughter John
GAP iiD BT-Sold
Post #389977 3rd Jun 2016 9:34am
Im intrigued why sour fitting a camera with the ign off? Care to share or is it private?
Post #389998 3rd Jun 2016 10:40am
EmiratesA380
Craig - Think about it ...... whilst car is at Airport - The camera has a motion detection on it and if anyone gets 4 feet in front or behind her then it records onto a HD.
LETS PUT IT ANOTHER WAY - you go to Tesco's and park you lovely FF their - you come back and Ms Marple has decided to reveres into it - enough said.
Post #390005 3rd Jun 2016 11:11am
'live feed' for the dashcam motion detection function?
edit, beat me to it .. ... - .- -.
Post #390007 3rd Jun 2016 11:12am
EmiratesA380
Stan - All I can Say is your TOP MAN Thumbs Up
have a good weekend mate
Post #390013 3rd Jun 2016 11:28am
Embarassed Wink ... - .- -.
Post #390025 3rd Jun 2016 11:48am
