Home > Maintenance & Mods (L322) > Rear window relay
STU TDV8
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Rear window relay
Does anyone know where the rear electric window relay is ?.. 2007 TDV8 3.6 ??..
Also the upper tailgate relay ?..
Post #390291 5th Jun 2016 5:53pm
I take it these are other faults you have... pretty sure they are on the BECM so maybe yours is toast...
You can get them tested/repaired if you send them off... this place is good but they are always stacked out so take a while to fix them....
http://www.ecutesting.com/?utm_expid=32378...e.co.uk%2F Pete
Post #390300 5th Jun 2016 6:54pm
STU TDV8
Im not sure what's wrong , I had an issue with my air suspension which ended up to be a high resistance joint in the boot where the 3 earth's are behind the spare wheel . So fixed that then when to test drive it up the road and the steering was heavy and the rear two door's both had electric window issue's ? . Also the top tailgate doesn't open on the key or dash control etc ??....
Post #390305 5th Jun 2016 7:36pm
In that case I'd check the earth under the carpet at the front, it will mean taking the passenger seat out and side trim and carpet...
DO'NT turn the ignition on with the seat out, it will put on the airbag light and you need a diagnostic tool to turn it off... Pete
Post #390308 5th Jun 2016 8:03pm
This is the earth point, all the brown wires...
Details on how to get to it from about 1/2 way down the first page in this thread...
http://www.fullfatrr.com/forum/topic29219.html
Thumbs Up :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #390309 5th Jun 2016 8:07pm
STU TDV8
Thank's haylands you have been a great help ill do it in the next couple of day's !...
Post #390312 5th Jun 2016 8:17pm
If you want to test it before it goes back together, just lay the seat in place and plug it in, wouldn't drive far though...!!!
If it is the BECM ring that company and they will give you a price for fixing it.... Pete
Post #390313 5th Jun 2016 8:24pm
STU TDV8
Tested the earth's tonight and there all good so guess it's the BECM ? ..
Post #390653 7th Jun 2016 10:36pm
There has been a spate of Body Processor Modules failing recently mine included , all around the same age as well . 2008 MY Supercharged
Post #390671 8th Jun 2016 2:01am
STU TDV8
Anybody know if the TD6 BECM unit will work on the TDV8 2007 ?..
Post #390978 9th Jun 2016 9:42pm
Give Dan a ring, or send him a message he'll be able to tell... Thumbs Up Pete
Post #390984 9th Jun 2016 10:37pm
