![]() | Home > Technical (L322) > Which code reader |
mogman50 Member Since: 29 Sep 2014 Location: Settle Posts: 37 ![]() ![]() ![]() |
Thanks for the confirmation. It is not possible to reset the service indicator on a TDV8 manually but I had hoped there was a cheaper alternative to having to buy the more expensive code reader. I think I'll just ignore the message for the time being.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
The Blackbox Solutions Faultmate MSV-2 diagnostic system that I had for my 2003 model, which cost north of £1000, had a ‘reset service interval indicator’ button:
Thanks Phil.
Once they went with the fibreoptic infotainment system the ability to clear the service indicator dispersed somewhere into the ether but an iiD Tool can reset it like the others mentioned and it can change the intervals it goes off as well . 2008 MY Supercharged
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
There are now 2 types of iCarsoft unit, the newer pro model advertises service interval reset........If you go down the page in the ebay link there is a Foxwell unit thay says it does even more??
Wylie66 Member Since: 10 Jan 2016 Location: Bushey Posts: 67 ![]() ![]() ![]() |
OOO I say that Foxwell 510 is tempting, allegedly will calibrate suspension as well.
GoatBoy Member Since: 27 Oct 2016 Location: North Yorkshire, Gods own county Posts: 4 ![]() ![]() ![]() |
Hi all,
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
If there is some kind person near you with a GapiiD tool they can clear the fault. Faults aren't VIN locked. John
Double post. |
Hi Weegie,
No. It was I who double posted. |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 ![]() ![]() ![]() |
MD 802 All System will read the air suspension and more. Just make sure it's the All System, as they do a basic 4 system also. Don't rely on the description, ask the seller the question. |
so, I'm now the proud owner of an iCarsoft LRII it cost me £130 on the bay of E. Had my suspension up and running in about 2 minutes. It LIVES!!!!!
